MRO
:Hello,I'm trying to replace a speaker for a pre-1942 Motorola console, has a 10 inch speaker that has a 800 ohms field coil thats bad, can this be replaced with a different 10 inch speaker say one with a 900 or 1000 ohms field coil speaker that has the higher resistance and would it work right? I've have'nt found out yet if the original can be re-wound since its field coil is sandwiched between two brackets spot welded on the ends,so just checking out options.Thanks!Mike L.
The resistance should not be very critical. They designed those old radios with a lot of loose space in the specs for tube aging, so a 10 or even 20 per cent change should work just fine. Twenty per cent resistors were the norm for those days, and as the tubes aged, everything still worked just fine and dandy. Try it, I think you'll like it.
:Hello Thomas,I'm interested in learning about how to shunt the speaker field coil,like say its original speaker was 800ohms now using another speaker at 930 ohms the difference is 130 ohms so in shunting does this go between the two field coil wires? or only one resistor to one wire? would this be a 130 ohm resistor?& the start side or finish side? or (2) resistors divided out one to each of both wires?,I'm not sure how shunting works or how it is wired.Thanks,Mike L.
:Hello Marv,I read your posting and now understand how to wire it,I also see how the 797ohms is derived I took the 930x5600=5208000. then 930+5600=6530 so dividing the 5208000.by 6530=797.54977 so I thought I would share this with anyone else trying to figure the math on how to shunt a field coil speaker one with higher ohms than the original field coil speaker if you needed to.Thanks for your help!Mike L.
1/Rtotal=1/R1+1/R2+1/R3....
When you use the R1+R2/R1 times R2, you are really doing the same thing as you would with the first formula.
