Terry F
:Hi , i replaced all of the caps, and found a new transformer(120-6). i had an old battery charger that was 6 volts at 3 amps, and that was just what I needed., i also got rid of the old makeshift type 41 half wave rectifier, and added a brand new silicon diode full was rectifier. Finally radioshack had something usefull! 2 days ago i had ten days to get this radio completly restored, i thought this was impossible. i sat down for 3 hours and installed all 19 caps, rectifier, and transformer, then started refinishing the cabinet, all of today i was replaceing wood supports in the radio. i purchased this radio from a man in ohio , in a region which has common floods. most off the base is rotted from water damaged so i had to replace most of the base wood. the only thing i still need to due is replace the speaker cloth,i ordered a piece of pattern 67 from grillecloth.com, is this the right pattern for this radio? it seems close , but something tells me it not it. Do any of you know what the right cloth is, or if that pattern is the right cloth? thanks
