Check the resistors across the 1st video IF transformer (12K) and the 2nd (10K).
Might be a bad IF transformer, but I don't think so as the waveform is good; I would expect a lousy waveform with a shorted/open winding.
I don't know if this is a clue or not. On a given channel, when I adjust the fine tuning to get the best picture, I also tune in a "buzz". The buzz disappears with slight adjustment either way. I sure wish my sound was where the buzz is!
The audio is still there but it takes approximately 1/2 turn of the oscillator screw. But by then, the picture is toast.
This is a very early TV. The problem was fairly common in the 1950's. Could be alignment but you might also try less input signal. A strong signal might overpower the TV causing video buzz in audio.
::Might be a bad IF transformer, but I don't think so as the waveform is good; I would expect a lousy waveform with a shorted/open winding.
:I don't know if this is a clue or not. On a given channel, when I adjust the fine tuning to get the best picture, I also tune in a "buzz". The buzz disappears with slight adjustment either way. I sure wish my sound was where the buzz is!
:The audio is still there but it takes approximately 1/2 turn of the oscillator screw. But by then, the picture is toast.
Rene:
How about looking at the audio IF? Maybe it's not 4.5 mHz anymore???
After doing some reading on stagger-tuned video amplifiers, I'm starting to think that the amplifier tuned at the low end (22 MHz) is the one that is way off...hopefully something simple like a resistor but likely it's a bad transformer.
Yes, that's exactly what I'm thinking about....well, back to the thinking cap.
