The chassic has several wire in need replacement or covering with heat shrink as it is very brittle and cracked in laces.
Will heat shrinking the old wiring work well?
Should I just replace the wiring?
Or are there any suggestions?
Rick
Might be better to just replace each segment of wire that is bad?
Doug
:Hello,
: I recently purchased a 1942 Zenith Tabletop radio. You can view it at http://phonoold1.tripod.com/Zenith_6D612.html
:The chassic has several wire in need replacement or covering with heat shrink as it is very brittle and cracked in laces.
:Will heat shrinking the old wiring work well?
:Should I just replace the wiring?
:Or are there any suggestions?
:Thanks
:Rick
Rick, I agree with Doug, you will be going to about the same amount of trouble either way, so why not just do it properly?
::Hello,
:: I recently purchased a 1942 Zenith Tabletop radio. You can view it at http://phonoold1.tripod.com/Zenith_6D612.html
::The chassic has several wire in need replacement or covering with heat shrink as it is very brittle and cracked in laces.
::Will heat shrinking the old wiring work well?
::Should I just replace the wiring?
::Or are there any suggestions?
::Thanks
::Rick
Rick
:Hello,
:Thanks
:Rick
Just about any reasonable gauge would be OK, 22 probobly is easiest to work with, and is probably what they used in the first place.
::Doug and Lewis,
:: Thanks for the help. I will probably replace the wiring that I can. So of the brittle, cracked wiring comes from tuning coils so I may have to heat shrink them.
:: What about gauge?? Do I need to maintain the same gauge or will todays wiring be of a lighter gauge? Is there a web sit which sells wiring for antique radios?
::Thanks
::Rick
:Just about any reasonable gauge would be OK, 22 probobly is easiest to work with, and is probably what they used in the first place.
:Lewis
rick
:Doug and Lewis,
:Thanks
:Rick
::Hello,
::Thanks
::Rick
