46-1209 No SW
6/27/2007 2:26:10 PMDave Froehlich
Hello All,
In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
What should I look at next?
6/27/2007 3:40:59 PMJohnnysan
:Hello All,
: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
: What should I look at next?
:Thanks,
:Dave
If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 3:56:40 PMDave Froehlich
Johnnysan,
OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
Dave:
:Hello All,
:: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:: What should I look at next?
::Thanks,
::Dave
:If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 4:05:13 PMDave Froehlich
Johnnysan,
I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:Johnnysan,
: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:Thanks,
:Dave:
::Hello All,
::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::: What should I look at next?
:::Thanks,
:::Dave
::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 4:15:02 PMRadiodoc
Dave,
May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:Johnnysan,
: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:Thanks,
:Dave
::Johnnysan,
:: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
::Thanks,
::Dave:
:::Hello All,
:::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:::: What should I look at next?
::::Thanks,
::::Dave
:::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 5:36:08 PMEdd
Looking at the specs of the two tubes, there is quite a difference if you were wanting a unit for some serious RF work.
Both of the units being dual triodes within a common envelope, the envelope profile of the 7F8 being a short and
squatty unit and the 7AF7 unit being of standard full envelope length.
The 7AF7 tube being of the "common amplifier" category, whereas the 7F8's specs exemplifies all of a full 300 Mhz
freq rating range. It also having the desired lower interelectrode capacitances all across the board.
The 7AF7 rates a 2100 umho transconductance figure while the 7F8 sports a 3300 figure.
Then there is the gain aspect of the 7AF7 at a mere 16....with the 7A8 being at a 48 level.
Now I don't know about your band of shortwave that you are referring to , but the lower ones nearest the BC band would
be much less discriminating, but on up the spectrum and particularly if for the FM band, the choice would be simple.
Back in the earlier big tubes sockets days and their leads and internal wiring.......the direct leaded configuration of the
locktals certainly solved that "baggage" problem in scaling up the frequency capabilities of circuitry incorporating them.
Referencing to 7F8 tube data is HERE
Referencing to 7AF7 tube data is HERE
:Dave,
:May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:Radiodoc
::Johnnysan,
:: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
:: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
::Thanks,
::Dave
:::Johnnysan,
::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:::Thanks,
:::Dave:
::::Hello All,
::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::::: What should I look at next?
:::::Thanks,
:::::Dave
::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 6:02:51 PMDave Froehlich
Edd,
I found the problem. Someone replaced the 150pf capacitor with a .0047 mf capacitor. 4700pf is a bit high. With the .0047 disconnected I receive short wave just fine. But I probably need the 150 pf capacitor because I only get 1400 and above on the BC band.
I'll find a tiny capacitor and try it out.
This radio has no FM. So on to the capacitor re-replacement.
:Looking at the specs of the two tubes, there is quite a difference if you were wanting a unit for some serious RF work.
:Both of the units being dual triodes within a common envelope, the envelope profile of the 7F8 being a short and
:squatty unit and the 7AF7 unit being of standard full envelope length.
:The 7AF7 tube being of the "common amplifier" category, whereas the 7F8's specs exemplifies all of a full 300 Mhz
:freq rating range. It also having the desired lower interelectrode capacitances all across the board.
:The 7AF7 rates a 2100 umho transconductance figure while the 7F8 sports a 3300 figure.
:Then there is the gain aspect of the 7AF7 at a mere 16....with the 7A8 being at a 48 level.
:Now I don't know about your band of shortwave that you are referring to , but the lower ones nearest the BC band would
:be much less discriminating, but on up the spectrum and particularly if for the FM band, the choice would be simple.
:Back in the earlier big tubes sockets days and their leads and internal wiring.......the direct leaded configuration of the
:locktals certainly solved that "baggage" problem in scaling up the frequency capabilities of circuitry incorporating them.
:Referencing to 7F8 tube data is HERE
:Referencing to 7AF7 tube data is HERE
::Dave,
::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
::Radiodoc
:::Johnnysan,
::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:::Thanks,
:::Dave
::::Johnnysan,
:::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
::::Thanks,
::::Dave:
:::::Hello All,
:::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:::::: What should I look at next?
::::::Thanks,
::::::Dave
:::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 6:18:13 PMDave Froehlich
Edd,
I seem to have misplaced my teeny tiny value capacitors. I almost never need that size and RS doesn't carry that size anymore. So I guess (as silly as it sounds) I'll have to mail-order a 150pf capacitor. Maybe if I search my place, after several hours I'll find it. This is very disappointing.
When I do find it, I'll let everyone know how the radio is working.
:Edd,
: I found the problem. Someone replaced the 150pf capacitor with a .0047 mf capacitor. 4700pf is a bit high. With the .0047 disconnected I receive short wave just fine. But I probably need the 150 pf capacitor because I only get 1400 and above on the BC band.
: I'll find a tiny capacitor and try it out.
: This radio has no FM. So on to the capacitor re-replacement.
:Thanks,
:Dave
::Looking at the specs of the two tubes, there is quite a difference if you were wanting a unit for some serious RF work.
::Both of the units being dual triodes within a common envelope, the envelope profile of the 7F8 being a short and
::squatty unit and the 7AF7 unit being of standard full envelope length.
::The 7AF7 tube being of the "common amplifier" category, whereas the 7F8's specs exemplifies all of a full 300 Mhz
::freq rating range. It also having the desired lower interelectrode capacitances all across the board.
::The 7AF7 rates a 2100 umho transconductance figure while the 7F8 sports a 3300 figure.
::Then there is the gain aspect of the 7AF7 at a mere 16....with the 7A8 being at a 48 level.
::Now I don't know about your band of shortwave that you are referring to , but the lower ones nearest the BC band would
::be much less discriminating, but on up the spectrum and particularly if for the FM band, the choice would be simple.
::Back in the earlier big tubes sockets days and their leads and internal wiring.......the direct leaded configuration of the
::locktals certainly solved that "baggage" problem in scaling up the frequency capabilities of circuitry incorporating them.
::Referencing to 7F8 tube data is HERE
::Referencing to 7AF7 tube data is HERE
::73's de Edd
:::Dave,
:::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:::Radiodoc
::::Johnnysan,
:::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
:::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
::::Thanks,
::::Dave
:::::Johnnysan,
::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:::::Thanks,
:::::Dave:
::::::Hello All,
::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::::::: What should I look at next?
:::::::Thanks,
:::::::Dave
::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 6:27:29 PMEdd
Yep....local osc to mixer injection capacitor.....C5 150 pf.....between the LO/MIX cathodes circuitry...that MUCH higher value would tend to overcouple.....load down...and swamp down things a bit.
Addenda:...have several new El Menco silver micas of that value ...can mail if needed...RSVP.
:Edd,
: I seem to have misplaced my teeny tiny value capacitors. I almost never need that size and RS doesn't carry that size anymore. So I guess (as silly as it sounds) I'll have to mail-order a 150pf capacitor. Maybe if I search my place, after several hours I'll find it. This is very disappointing.
: When I do find it, I'll let everyone know how the radio is working.
:Thanks,
:Dave
::Edd,
:: I found the problem. Someone replaced the 150pf capacitor with a .0047 mf capacitor. 4700pf is a bit high. With the .0047 disconnected I receive short wave just fine. But I probably need the 150 pf capacitor because I only get 1400 and above on the BC band.
:: I'll find a tiny capacitor and try it out.
:: This radio has no FM. So on to the capacitor re-replacement.
::Thanks,
::Dave
:::Looking at the specs of the two tubes, there is quite a difference if you were wanting a unit for some serious RF work.
:::Both of the units being dual triodes within a common envelope, the envelope profile of the 7F8 being a short and
:::squatty unit and the 7AF7 unit being of standard full envelope length.
:::The 7AF7 tube being of the "common amplifier" category, whereas the 7F8's specs exemplifies all of a full 300 Mhz
:::freq rating range. It also having the desired lower interelectrode capacitances all across the board.
:::The 7AF7 rates a 2100 umho transconductance figure while the 7F8 sports a 3300 figure.
:::Then there is the gain aspect of the 7AF7 at a mere 16....with the 7A8 being at a 48 level.
:::Now I don't know about your band of shortwave that you are referring to , but the lower ones nearest the BC band would
:::be much less discriminating, but on up the spectrum and particularly if for the FM band, the choice would be simple.
:::Back in the earlier big tubes sockets days and their leads and internal wiring.......the direct leaded configuration of the
:::locktals certainly solved that "baggage" problem in scaling up the frequency capabilities of circuitry incorporating them.
:::Referencing to 7F8 tube data is HERE
:::Referencing to 7AF7 tube data is HERE
:::73's de Edd
::::Dave,
::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
::::Radiodoc
:::::Johnnysan,
::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:::::Thanks,
:::::Dave
::::::Johnnysan,
:::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
::::::Thanks,
::::::Dave:
:::::::Hello All,
:::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:::::::: What should I look at next?
::::::::Thanks,
::::::::Dave
:::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 7:31:44 PMDave Froehlich
Edd,
I found some low value capacitors. I tried 180 pf, no SW great BC, 150 pf, no SW geat BC. 10pf gives nice strong SW but nice weak BC. So it must be somewhere between 10 and 68 because I tried that too. I'll try 30pf and 47pf. These are teeny tiny but I've seen values like this in 5 tube table radios. I remember once I was working on one where someone substituted a 47mf electrolytic capacitor for a 47pf mica capacitor. That didn't work well either.
:Yep....local osc to mixer injection capacitor.....C5 150 pf.....between the LO/MIX cathodes circuitry...that MUCH higher value would tend to overcouple.....load down...and swamp down things a bit.
:Addenda:...have several new El Menco silver micas of that value ...can mail if needed...RSVP.
::Edd,
:: I seem to have misplaced my teeny tiny value capacitors. I almost never need that size and RS doesn't carry that size anymore. So I guess (as silly as it sounds) I'll have to mail-order a 150pf capacitor. Maybe if I search my place, after several hours I'll find it. This is very disappointing.
:: When I do find it, I'll let everyone know how the radio is working.
::Thanks,
::Dave
:::Edd,
::: I found the problem. Someone replaced the 150pf capacitor with a .0047 mf capacitor. 4700pf is a bit high. With the .0047 disconnected I receive short wave just fine. But I probably need the 150 pf capacitor because I only get 1400 and above on the BC band.
::: I'll find a tiny capacitor and try it out.
::: This radio has no FM. So on to the capacitor re-replacement.
:::Thanks,
:::Dave
::::Looking at the specs of the two tubes, there is quite a difference if you were wanting a unit for some serious RF work.
::::Both of the units being dual triodes within a common envelope, the envelope profile of the 7F8 being a short and
::::squatty unit and the 7AF7 unit being of standard full envelope length.
::::The 7AF7 tube being of the "common amplifier" category, whereas the 7F8's specs exemplifies all of a full 300 Mhz
::::freq rating range. It also having the desired lower interelectrode capacitances all across the board.
::::The 7AF7 rates a 2100 umho transconductance figure while the 7F8 sports a 3300 figure.
::::Then there is the gain aspect of the 7AF7 at a mere 16....with the 7A8 being at a 48 level.
::::Now I don't know about your band of shortwave that you are referring to , but the lower ones nearest the BC band would
::::be much less discriminating, but on up the spectrum and particularly if for the FM band, the choice would be simple.
::::Back in the earlier big tubes sockets days and their leads and internal wiring.......the direct leaded configuration of the
::::locktals certainly solved that "baggage" problem in scaling up the frequency capabilities of circuitry incorporating them.
::::Referencing to 7F8 tube data is HERE
::::Referencing to 7AF7 tube data is HERE
::::73's de Edd
:::::Dave,
:::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:::::Radiodoc
::::::Johnnysan,
:::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
:::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
::::::Thanks,
::::::Dave
:::::::Johnnysan,
::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:::::::Thanks,
:::::::Dave:
::::::::Hello All,
::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::::::::: What should I look at next?
:::::::::Thanks,
:::::::::Dave
::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/27/2007 8:12:40 PMDave Froehlich
Radiodoc,
A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
The original tube used a 150 pf. That absolutely wont work here.
:Dave,
:Radiodoc
::Johnnysan,
::Thanks,
::Dave
:::Johnnysan,
:::Thanks,
:::Dave:
::::Hello All,
:::::Thanks,
:::::Dave
6/27/2007 9:33:24 PMElton
:Radiodoc,
: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
: The original tube used a 150 pf. That absolutely wont work here.
::Dave,
::Radiodoc
:::Johnnysan,
:::Thanks,
:::Dave
::::Johnnysan,
::::Thanks,
::::Dave:
:::::Hello All,
::::::Thanks,
::::::Dave
Hi Dave I have the same radio with the same problem, no SW are you refering to cap C5 in the schematic? I might as well check mine also who knows...
E.
6/27/2007 9:43:07 PMRadiodoc
Dave,
As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
:Radiodoc,
::Dave,
::Radiodoc
:::Johnnysan,
:::Thanks,
:::Dave
::::Johnnysan,
::::Thanks,
::::Dave:
:::::Hello All,
::::::Thanks,
::::::Dave
6/28/2007 10:06:44 AMEdd
:Dave,
:As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
:Radiodoc
::Radiodoc,
:: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
:: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
:: The original tube used a 150 pf. That absolutely wont work here.
:::Dave,
:::Radiodoc
::::Johnnysan,
::::Thanks,
::::Dave
:::::Johnnysan,
:::::Thanks,
:::::Dave:
::::::Hello All,
:::::::Thanks,
:::::::Dave
6/28/2007 9:14:54 PMDave Froehlich
Edd,
I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
But 37 pf seems to work fine.
I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
then being able to select that value of fixed capacitor if all works well with that capacitance value.
[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
::Dave,
::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
::Radiodoc
:::Radiodoc,
::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
::: The original tube used a 150 pf. That absolutely wont work here.
::::Dave,
::::Radiodoc
:::::Johnnysan,
:::::Thanks,
:::::Dave
::::::Johnnysan,
::::::Thanks,
::::::Dave:
:::::::Hello All,
::::::::Thanks,
::::::::Dave
6/29/2007 2:06:41 PMFred R
Dave,
I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
Fred
:Edd,
:I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
: But 37 pf seems to work fine.
:Thanks,
:Dave
:I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
:the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
:What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
:compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
:tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
:then being able to select that value of fixed capacitor if all works well with that capacitance value.
:[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
:::Dave,
:::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
:::Radiodoc
::::Radiodoc,
:::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
:::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
:::: The original tube used a 150 pf. That absolutely wont work here.
:::::Dave,
:::::Radiodoc
::::::Johnnysan,
::::::Thanks,
::::::Dave
:::::::Johnnysan,
:::::::Thanks,
:::::::Dave:
::::::::Hello All,
:::::::::Thanks,
:::::::::Dave
6/29/2007 2:54:58 PMDave Froehlich
Fred,
I wonder if there was a service bulletin about this change.
I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
:Dave,
:I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
:Fred
::Edd,
::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
:: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
:: But 37 pf seems to work fine.
::Thanks,
::Dave
::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
::then being able to select that value of fixed capacitor if all works well with that capacitance value.
::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
::73's de Edd
::::Dave,
::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
::::Radiodoc
:::::Radiodoc,
::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
::::: The original tube used a 150 pf. That absolutely wont work here.
::::::Dave,
::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
::::::Radiodoc
:::::::Johnnysan,
::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:::::::Thanks,
:::::::Dave
::::::::Johnnysan,
:::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
::::::::Thanks,
::::::::Dave:
:::::::::Hello All,
:::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:::::::::: What should I look at next?
::::::::::Thanks,
::::::::::Dave
:::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/29/2007 3:17:42 PMDave Froehlich
Fred,
Look what I found on a web page:
It clearly shows a 7AF7 in a 46-1209. Why does Riders Show a 7F8 in this radio?
:Fred,
: I wonder if there was a service bulletin about this change.
:I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
:Thanks,
::Dave,
::I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
::Fred
:::Edd,
:::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
::: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
::: But 37 pf seems to work fine.
:::Thanks,
:::Dave
:::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
:::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
:::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
:::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
:::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
:::then being able to select that value of fixed capacitor if all works well with that capacitance value.
:::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
:::73's de Edd
:::::Dave,
:::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
:::::Radiodoc
::::::Radiodoc,
:::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
:::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
:::::: The original tube used a 150 pf. That absolutely wont work here.
:::::::Dave,
:::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:::::::Radiodoc
::::::::Johnnysan,
:::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
:::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
::::::::Thanks,
::::::::Dave
:::::::::Johnnysan,
::::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:::::::::Thanks,
:::::::::Dave:
::::::::::Hello All,
::::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::::::::::: What should I look at next?
:::::::::::Thanks,
:::::::::::Dave
::::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/29/2007 3:19:34 PMDave Froehlich
Fred,
Here's an even better picture. This confirms that this tube was original to the 46-1209.
:Fred,
: Look what I found on a web page:
:It clearly shows a 7AF7 in a 46-1209. Why does Riders Show a 7F8 in this radio?
:Dave
::Fred,
:: I wonder if there was a service bulletin about this change.
::I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
::Thanks,
:::Dave,
:::I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
:::Fred
::::Edd,
::::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
:::: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
:::: But 37 pf seems to work fine.
::::Thanks,
::::Dave
::::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
::::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
::::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
::::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
::::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
::::then being able to select that value of fixed capacitor if all works well with that capacitance value.
::::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
::::73's de Edd
::::::Dave,
::::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
::::::Radiodoc
:::::::Radiodoc,
::::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
::::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
::::::: The original tube used a 150 pf. That absolutely wont work here.
::::::::Dave,
::::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
::::::::Radiodoc
:::::::::Johnnysan,
::::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
::::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:::::::::Thanks,
:::::::::Dave
::::::::::Johnnysan,
:::::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
::::::::::Thanks,
::::::::::Dave:
:::::::::::Hello All,
:::::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:::::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:::::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:::::::::::: What should I look at next?
::::::::::::Thanks,
::::::::::::Dave
:::::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/29/2007 3:24:42 PMDave Froehlich
Fred,
I made a mistake. Double checking the picture, I see that it is the pre-amp/inverter tube that is a 7AF7. 7F8 is still the mixer/oscillator. The set I have here has a 7F7 in place of the 7AF7 as the pre-amp/inverter tube.
So I'm still in need of a schematic showing a 7AF7 as the mixer/oscillator tube.
:Fred,
: Here's an even better picture. This confirms that this tube was original to the 46-1209.
:Dave
::Fred,
:: Look what I found on a web page:
::It clearly shows a 7AF7 in a 46-1209. Why does Riders Show a 7F8 in this radio?
::Dave
:::Fred,
::: I wonder if there was a service bulletin about this change.
:::I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
:::Thanks,
::::Dave,
::::I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
::::Fred
:::::Edd,
:::::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
::::: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
::::: But 37 pf seems to work fine.
:::::Thanks,
:::::Dave
:::::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
:::::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
:::::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
:::::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
:::::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
:::::then being able to select that value of fixed capacitor if all works well with that capacitance value.
:::::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
:::::73's de Edd
:::::::Dave,
:::::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
:::::::Radiodoc
::::::::Radiodoc,
:::::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
:::::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
:::::::: The original tube used a 150 pf. That absolutely wont work here.
:::::::::Dave,
:::::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:::::::::Radiodoc
:::::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
:::::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
::::::::::Thanks,
::::::::::Dave
:::::::::::Johnnysan,
::::::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:::::::::::Thanks,
:::::::::::Dave:
::::::::::::Hello All,
::::::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::::::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::::::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::::::::::::: What should I look at next?
:::::::::::::Thanks,
:::::::::::::Dave
::::::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/29/2007 5:07:48 PMFred R
Dave,
You don't want to start changing things until you are sure what is supposed to be there. Let me check. I have original Philco service notes for these sets. As I mentioned, these sets came with either tube depending on the run and they do not interchange. Also, what code is your set? That would be stamped on the chassis and on the tube sticker. I 'll post later. 7F7 is basically a 6SL7 where a 7F8 believe it or not performs much like a 12AT7. All the post war Philco AM-FM sets used 7F8s (or 14F8s) where as 7AF7 were only used in some AM-Short wave models.
Fred
:Fred,
: I made a mistake. Double checking the picture, I see that it is the pre-amp/inverter tube that is a 7AF7. 7F8 is still the mixer/oscillator. The set I have here has a 7F7 in place of the 7AF7 as the pre-amp/inverter tube.
: So I'm still in need of a schematic showing a 7AF7 as the mixer/oscillator tube.
:Thanks,
:Dave
::Fred,
:: Here's an even better picture. This confirms that this tube was original to the 46-1209.
::Dave
:::Fred,
::: Look what I found on a web page:
:::It clearly shows a 7AF7 in a 46-1209. Why does Riders Show a 7F8 in this radio?
:::Dave
::::Fred,
:::: I wonder if there was a service bulletin about this change.
::::I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
::::Thanks,
:::::Dave,
:::::I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
:::::Fred
::::::Edd,
::::::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
:::::: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
:::::: But 37 pf seems to work fine.
::::::Thanks,
::::::Dave
::::::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
::::::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
::::::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
::::::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
::::::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
::::::then being able to select that value of fixed capacitor if all works well with that capacitance value.
::::::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
::::::73's de Edd
::::::::Dave,
::::::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
::::::::Radiodoc
:::::::::Radiodoc,
::::::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
::::::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
::::::::: The original tube used a 150 pf. That absolutely wont work here.
::::::::::Dave,
::::::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
::::::::::Radiodoc
::::::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
::::::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:::::::::::Thanks,
:::::::::::Dave
::::::::::::Johnnysan,
:::::::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
::::::::::::Thanks,
::::::::::::Dave:
:::::::::::::Hello All,
:::::::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:::::::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:::::::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:::::::::::::: What should I look at next?
::::::::::::::Thanks,
::::::::::::::Dave
:::::::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/29/2007 6:36:43 PMFred R
Dave,
I checked through my Philco book. The tube layout you posted is for code 121 chassis which is the earliest. Mine was the later version which used two 7AF7s, one for the converter and the other for audio phase splitter and phono preamp. My service book has a lot of handwritten notes pertaining to the version with the 7AF7 including voltages. There were two different detector/first audio tubes in this model. The coded 121 used a 7X7 first audio amp and one diode for second detector and AVC. My later 46-1209 used a 7C6 here. So that makes three versions of this set. I can scan you the info if you like.
Fred
:Dave,
:You don't want to start changing things until you are sure what is supposed to be there. Let me check. I have original Philco service notes for these sets. As I mentioned, these sets came with either tube depending on the run and they do not interchange. Also, what code is your set? That would be stamped on the chassis and on the tube sticker. I 'll post later. 7F7 is basically a 6SL7 where a 7F8 believe it or not performs much like a 12AT7. All the post war Philco AM-FM sets used 7F8s (or 14F8s) where as 7AF7 were only used in some AM-Short wave models.
:Fred
::Fred,
:: I made a mistake. Double checking the picture, I see that it is the pre-amp/inverter tube that is a 7AF7. 7F8 is still the mixer/oscillator. The set I have here has a 7F7 in place of the 7AF7 as the pre-amp/inverter tube.
:: So I'm still in need of a schematic showing a 7AF7 as the mixer/oscillator tube.
::Thanks,
::Dave
:::Fred,
::: Here's an even better picture. This confirms that this tube was original to the 46-1209.
:::Dave
::::Fred,
:::: Look what I found on a web page:
::::It clearly shows a 7AF7 in a 46-1209. Why does Riders Show a 7F8 in this radio?
::::Dave
:::::Fred,
::::: I wonder if there was a service bulletin about this change.
:::::I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
:::::Thanks,
::::::Dave,
::::::I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
::::::Fred
:::::::Edd,
:::::::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
::::::: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
::::::: But 37 pf seems to work fine.
:::::::Thanks,
:::::::Dave
:::::::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
:::::::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
:::::::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
:::::::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
:::::::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
:::::::then being able to select that value of fixed capacitor if all works well with that capacitance value.
:::::::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
:::::::73's de Edd
:::::::::Dave,
:::::::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
:::::::::Radiodoc
::::::::::Radiodoc,
:::::::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
:::::::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
:::::::::: The original tube used a 150 pf. That absolutely wont work here.
:::::::::::Dave,
:::::::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:::::::::::Radiodoc
:::::::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
:::::::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
::::::::::::Thanks,
::::::::::::Dave
:::::::::::::Johnnysan,
::::::::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:::::::::::::Dave:
::::::::::::::Hello All,
::::::::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::::::::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::::::::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::::::::::::::: What should I look at next?
:::::::::::::::Thanks,
:::::::::::::::Dave
::::::::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/30/2007 6:20:02 AMDave Froehlich
Fred,
This chassis is indeed a code 122. It says "46-1209-122". That is stamped on the back. What page is that on in RIders? I have volume 15. But I don't think Riders covered it. But maybe SAMs did.
:Dave,
:Fred
::Fred,
::Thanks,
::Dave
:::Fred,
:::Dave
::::Fred,
::::Dave
:::::Fred,
:::::Thanks,
::::::Dave,
::::::Fred
:::::::Edd,
:::::::Thanks,
:::::::Dave
::::::::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
::::::::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
::::::::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
::::::::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
::::::::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
::::::::then being able to select that value of fixed capacitor if all works well with that capacitance value.
::::::::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
::::::::73's de Edd
:::::::::Dave,
:::::::::Radiodoc
::::::::::Radiodoc,
:::::::::::Dave,
:::::::::::Radiodoc
::::::::::::Thanks,
::::::::::::Dave
:::::::::::::Dave:
:::::::::::::::Dave
6/30/2007 7:41:21 AMFred R
Dave,
I checked SAMS and they only give the code 121 with the 7F8. 7F8 is the only loctal that doesn't use pin 1 and 8 for heater connection. The 7F8 uses 2 and 7 for its heater which makes it non-interchangeable with any other loctal. Going through my original service notes, there is a notation to refer to model 46-431 for the 7AF7 converter circuit. These sets all use modular assemblies for the tuner. The 46-431 uses the 7AF7 for the converter and a 7H7 IF both mounted on the tuner assembly. The 46-431 is not in Riders but I have the original Philco service notes I can scan for you. This will give you the circuit of your 46-1209.
Fred
:Fred,
: This chassis is indeed a code 122. It says "46-1209-122". That is stamped on the back. What page is that on in RIders? I have volume 15. But I don't think Riders covered it. But maybe SAMs did.
:Thanks,
::Dave,
::You don't want to start changing things until you are sure what is supposed to be there. Let me check. I have original Philco service notes for these sets. As I mentioned, these sets came with either tube depending on the run and they do not interchange. Also, what code is your set? That would be stamped on the chassis and on the tube sticker. I 'll post later. 7F7 is basically a 6SL7 where a 7F8 believe it or not performs much like a 12AT7. All the post war Philco AM-FM sets used 7F8s (or 14F8s) where as 7AF7 were only used in some AM-Short wave models.
::Fred
:::Fred,
::: I made a mistake. Double checking the picture, I see that it is the pre-amp/inverter tube that is a 7AF7. 7F8 is still the mixer/oscillator. The set I have here has a 7F7 in place of the 7AF7 as the pre-amp/inverter tube.
::: So I'm still in need of a schematic showing a 7AF7 as the mixer/oscillator tube.
:::Thanks,
:::Dave
::::Fred,
:::: Here's an even better picture. This confirms that this tube was original to the 46-1209.
::::Dave
:::::Fred,
::::: Look what I found on a web page:
:::::It clearly shows a 7AF7 in a 46-1209. Why does Riders Show a 7F8 in this radio?
:::::Dave
::::::Fred,
:::::: I wonder if there was a service bulletin about this change.
::::::I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
::::::Thanks,
:::::::Dave,
:::::::I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
:::::::Fred
::::::::Edd,
::::::::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
:::::::: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
:::::::: But 37 pf seems to work fine.
::::::::Thanks,
::::::::Dave
::::::::73's de Edd
::::::::::Dave,
::::::::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
::::::::::Radiodoc
:::::::::::Radiodoc,
::::::::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
::::::::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
::::::::::: The original tube used a 150 pf. That absolutely wont work here.
::::::::::::Dave,
::::::::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
::::::::::::Radiodoc
::::::::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
::::::::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
:::::::::::::Dave
::::::::::::::Johnnysan,
:::::::::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
::::::::::::::Dave:
:::::::::::::::Hello All,
:::::::::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
:::::::::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
:::::::::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
:::::::::::::::: What should I look at next?
::::::::::::::::Thanks,
::::::::::::::::Dave
:::::::::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/30/2007 8:20:31 PMDave Froehlich
Fred,
Yes, please scan the schematic and e-mail it to me. I believe that with the 7AF7, the 2.2K resistor and the .047 mf capacitor are correct. Something else is wrong. But what? This is extremely frustrating. There is also a 47K ohm resistor connecting pin 2 to pin 4. Pin 4 is connected to the chassis through an unknown component. Is that a 100 pf capacitor? Could the trouble may be with that component? With the .047mf capacitor and 2,2K resistor back in their places (in parallel with each other connecting pins 2 and 7). I get BC but no SW. Where should I look now? I now know that I have a 46-1209-122 with No SW.
:Dave,
:I checked SAMS and they only give the code 121 with the 7F8. 7F8 is the only loctal that doesn't use pin 1 and 8 for heater connection. The 7F8 uses 2 and 7 for its heater which makes it non-interchangeable with any other loctal. Going through my original service notes, there is a notation to refer to model 46-431 for the 7AF7 converter circuit. These sets all use modular assemblies for the tuner. The 46-431 uses the 7AF7 for the converter and a 7H7 IF both mounted on the tuner assembly. The 46-431 is not in Riders but I have the original Philco service notes I can scan for you. This will give you the circuit of your 46-1209.
:Fred
::Fred,
:: This chassis is indeed a code 122. It says "46-1209-122". That is stamped on the back. What page is that on in RIders? I have volume 15. But I don't think Riders covered it. But maybe SAMs did.
::Thanks,
:::Dave,
:::You don't want to start changing things until you are sure what is supposed to be there. Let me check. I have original Philco service notes for these sets. As I mentioned, these sets came with either tube depending on the run and they do not interchange. Also, what code is your set? That would be stamped on the chassis and on the tube sticker. I 'll post later. 7F7 is basically a 6SL7 where a 7F8 believe it or not performs much like a 12AT7. All the post war Philco AM-FM sets used 7F8s (or 14F8s) where as 7AF7 were only used in some AM-Short wave models.
:::Fred
::::Fred,
:::: I made a mistake. Double checking the picture, I see that it is the pre-amp/inverter tube that is a 7AF7. 7F8 is still the mixer/oscillator. The set I have here has a 7F7 in place of the 7AF7 as the pre-amp/inverter tube.
:::: So I'm still in need of a schematic showing a 7AF7 as the mixer/oscillator tube.
::::Thanks,
::::Dave
:::::Fred,
::::: Here's an even better picture. This confirms that this tube was original to the 46-1209.
:::::Dave
::::::Fred,
:::::: Look what I found on a web page:
::::::It clearly shows a 7AF7 in a 46-1209. Why does Riders Show a 7F8 in this radio?
::::::Dave
:::::::Fred,
::::::: I wonder if there was a service bulletin about this change.
:::::::I just sent an e-mail to the Philco Repair Bench to see if he (Chuck?) knows anything about the 7AF7. If he does, I'll probably find out what the component values are supposed to be.
:::::::Thanks,
::::::::Dave,
::::::::I had a 46-1209 years ago and mine came from the factory with a 7AF7 and showed one on the tube diagram in the cabinet. The original SAMS shows a 7F8 in the converter position. The same setup is used in the 46-1226 which is a similar model. The phono pickups were the difference between the models, the 1209 having the more expensive Philco Dynamic reproducer while the 1226 had a standard crystal pickup. The radios perform the same. I never had a problem with the 7AF7 in that set and shortwave worked fine. I am not sure why Philco switched the tube lineup. This was typical of Philco and the production changes are not always well documented.
::::::::Fred
:::::::::Edd,
:::::::::I tried replacing the 7AF7 with the 7F7, but the 7F7 definately will not work at all for mixer/oscillator. So there's differences between those two tubes as well.
::::::::: I'm pretty sure I have the value. But I thought of using a tiny trimmer capacitor and adjust it until it works and leave it. It's a modern one. It may not look good but it should work.
::::::::: But 37 pf seems to work fine.
:::::::::Thanks,
:::::::::Dave
:::::::::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
:::::::::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
:::::::::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
:::::::::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
:::::::::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
:::::::::then being able to select that value of fixed capacitor if all works well with that capacitance value.
:::::::::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
:::::::::73's de Edd
:::::::::::Dave,
:::::::::::As I have understood it, the 1R5 will work pretty well in the place of a 1L6 at the lower broadcast frequencies. It will work at the higher frequencies, but the radio frontend adjustments may have to be retuned and if the frequency is high enough, the adjustments may not compensate. In some circumstances pin 5 of the 1R5 may have to be cut off.
:::::::::::Radiodoc
::::::::::::Radiodoc,
:::::::::::: A 1L6 and !R5 have a different pin-outs. But somehow a 1R5 works. The 7F8 and 7AF7 have different pin-outs but the wiring was changed so that it is correct for the 7AF7. It's different. But the gain of the 7F8 was higher than that of the 7AF7. So that's what I'm probably experiencing.
:::::::::::: It will oscillate at the SW frequencies. But the capacitor I'm trying to come up with I may never find. It will have to be a compromise. Now I have very good SW but the gain drops off at the low end of the BC band. If I increase the value of the capacitor past 47 pf, SW will get weak but the BC band is nice and strong. Right now it's 37 pf, which I think is the best it's going to get.
:::::::::::: The original tube used a 150 pf. That absolutely wont work here.
:::::::::::::Dave,
:::::::::::::May be kinda like the saga of replacing the 1L6 with a 1R5, would work at the lower frequencies but struggled at the higher frequencies.
:::::::::::::Radiodoc
:::::::::::::: I just checked the tube data. A 7AF7 is the same as a 7N7 which is also the same as a 6SN7 or 12AX7 dual triode. It has an amplification factor of 16. A 7A8 has an amplification factor of 48. So it's 3 times as strong in amplifying than is a 7AF7.
:::::::::::::: 7A8 is the better tube, it seems. If I cannot get SW working, I'll assume that the 7AF7 cannot oscillate fast enough for SW frequencies.
::::::::::::::Dave
:::::::::::::::Johnnysan,
::::::::::::::: OK, I will add the resistor. The 7AF7 may be identical to the 7F8 except for Pin-out. So it might work. I'll let you know what happened when the 10K ohm resistor is added.
:::::::::::::::Dave:
::::::::::::::::Hello All,
::::::::::::::::: In this radio's past someone replaced the 7F8 with a 7AF7 and did a little re-wiring to make it work. I remember mentioning this here, but I don't remember when. Anyway, AM Broadcast band is working. When I got it, there was a 500 ohm resistor connecting the both cathodes together. This was incorrect. I added the correct 2.2K ohm resistor to the mixer cathode, and disconnected the 500 ohm resistor. So the BC is fine.
::::::::::::::::: The resistor on the SW front end is missing. But I don't see how it would make any difference. It's in parallel with a coil and trimmer capacitor. I get continuity on the SW oscillator coil. Maybe this tube wont work at SW frequencies? It seems that it should. So I'm not going to re-wire for the 7F8. SW does pick up clicks and things but no actual broadcasts.
::::::::::::::::: I haven't tried to put another radio radio near the oscillator coil to see if it's oscillating on the SW band. But I think that it's a good next step, not finding anything else wrong.
::::::::::::::::: What should I look at next?
:::::::::::::::::Thanks,
:::::::::::::::::Dave
::::::::::::::::If it were mine, I would put it back the way it was designed, then go from there. A resistor across a coil is for dampening; if it was made that way it was necessary for proper operation.
6/29/2007 3:27:36 PMThomas Dermody
I say put the circuit back to its original state. You don't want a low mu tube for short wave frequencies. The circuit must balance. As it was originally designed, it worked well as-is for both broadcast and short wave frequencies. When you have too much interelectrode capacitance, and not enough gain, you must significantly compensate external circuits to get the thing to oscillate at all at higher frequencies. Those compensations to reduce capacitance, so that the tube's internal capacitance doesn't couple to the oscillator coil and throw off its resonance, reduce the ability of the lower frequencies to pass through when the circuit is operated at broadcast frequencies. If you select a high mu tube with low interelectrode capacitance, the tube's internal capacitances will be insignificant, and you'll be able to use a coupling cap. of high enough value to pass broadcast frequencies, but since the tube's capacitance is low, the heavier coupling to the tube by the coupling cap. won't throw off the resonance of the short wave coil.
3/27/2010 3:30:12 PMPaul Knaack
:Hello All,
:Thanks,
:Dave
3/27/2010 6:27:33 PMMike C.
I have a Philco 46-1209 code 122 chassis here in front of me.It has the 7AF7 tube in the oscillator/mixer position.I believe the 7AF7 is correct for your radio as well.
3/28/2010 5:27:30 PMMike C.
Just a note of interest.I decided to part out the chassis that I have,it's pretty much junk,anyway.I tested the two Micamold,255pf capacitors attached to the bandswitch for leakage using a HeathkitIT-28.They both failed at only 6 volts.You might want to can those just to be on the safe side.That's assuming,of course,that your chassis has the same parts.I don't know what function they serve,as I don't have a schematic.
4/2/2010 11:16:05 PMDave Froehlich
Mike,
That's weird. I was just thinking of this chassis. It's been about 3 years since I looked at it. But I still have it. I'll take a look and see if these mica caps are a problem.
:Just a note of interest.I decided to part out the chassis that I have,it's pretty much junk,anyway.I tested the two Micamold,255pf capacitors attached to the bandswitch for leakage using a HeathkitIT-28.They both failed at only 6 volts.You might want to can those just to be on the safe side.That's assuming,of course,that your chassis has the same parts.I don't know what function they serve,as I don't have a schematic.
4/7/2010 2:03:35 AMIan
HI,
Anyone have a dial for this radio? Radiodaze doesnt know when they will order them.
Ian
:Mike,
: That's weird. I was just thinking of this chassis. It's been about 3 years since I looked at it. But I still have it. I'll take a look and see if these mica caps are a problem.
:Thanks,
:Dave
::Just a note of interest.I decided to part out the chassis that I have,it's pretty much junk,anyway.I tested the two Micamold,255pf capacitors attached to the bandswitch for leakage using a HeathkitIT-28.They both failed at only 6 volts.You might want to can those just to be on the safe side.That's assuming,of course,that your chassis has the same parts.I don't know what function they serve,as I don't have a schematic.
4/7/2010 2:03:43 AMIan
HI,
Ian
:Mike,
:Thanks,
:Dave
::::::::::I think that might possibly be attributable to that "plain vanilla" dual triode that is now sitting in the mixer osc position.......see its dupe being used in
::::::::::the tail end audio section of the receiver. Much higher and different interelectrode capacitances / elemental structuring on the "AF" tube.
::::::::::What you might try test evaluating ......considering the retention and use of that current "tube" in the front end is make a test attempt using a mica
::::::::::compression type of variable capacitor [***] temporarily solder tacked in and replacing the mentioned problematic cap. Use an insulated phenolic
::::::::::tool to run thru min / max capacitance adjustments to see where the balance in performance is between BC and SW stability / performance,
::::::::::then being able to select that value of fixed capacitor if all works well with that capacitance value.
::::::::::[***] Such as is used in pairs, for the top variable cap tuning of the larger older generation IF transformers.
::::::::::73's de Edd
