Hallicrafter Sky Buddy where do I find information on running the dil al cord. Mine busted an I don't know how to run the cord.
6/24/2007 8:45:07 PMWM Bilbrey
6/25/2007 10:36:33 AMDoug Criner
Did you try BAMA? http://bama.sbc.edu/
Doug
6/25/2007 1:23:52 PMEdd
See that, if between both of these sources of info, that you are able to get the "old war horse's'...( and heavy on the OLD) .... dials going again.
Sort of a follow the number system / connect the dots system used on the Hallicrafters systems dial cord routing, excluding the
partial wrap around the bandspread scale drum.
You might use twine on a preliminary test stringing to save your true " hi dollah " cord and compute a precise pre cut length as well as evaluate the tuning ease "action".....and some times, direction...in case you made a boo-boo.
Ref:
http://img123.imageshack.us/img123/8848/hallicraftersdialcordstix9.jpg
Also this mod by this person may or may not be helpful, as well as some other things that he encountered that might also be applicable in your situation.
http://www.w9wze.net/Restorations/S19/s19_6.jpg
http://www.w9wze.net/Restorations/S19/S19_KB9TMY.htm
---------------------------------------------------------------------------------------------BT----------------------------------------------------------------------------------------------
:Did you try BAMA? http://bama.sbc.edu/
:Doug
