5Y3 and 5Y4 are electrically the same. There is a small change you can make so either tube will operate.
Jumper between pin #3 and #4.
Jumper between pin #5 and #6.
Jumper between pin #2 and #7.
With these changes either tube can be used in the socket. Be sure the original socket is good. There will be high voltages between adjacent pins.
: I have two piece of equipment that use the 5Y4 as a full wave rectifier and have to spares on hand. I just purchased a piece of equipment which uses a 5Y3 as a full wave rectifier. The information that I have on the tubes indicates plate voltage 350-0-350V for both and Ir 125 for both. Pin Out is different but that's a one time change over. Also, 5Y3 sell for $10.00 plus while 5Y4 $6.00 plus. Will this work? Does anyone have any cautionary comments? PL
:Hi
: 5Y3 and 5Y4 are electrically the same. There is a small change you can make so either tube will operate.
: Jumper between pin #3 and #4.
: Jumper between pin #5 and #6.
: Jumper between pin #2 and #7.
: With these changes either tube can be used in the socket. Be sure the original socket is good. There will be high voltages between adjacent pins.
:: I have two piece of equipment that use the 5Y4 as a full wave rectifier and have to spares on hand. I just purchased a piece of equipment which uses a 5Y3 as a full wave rectifier. The information that I have on the tubes indicates plate voltage 350-0-350V for both and Ir 125 for both. Pin Out is different but that's a one time change over. Also, 5Y3 sell for $10.00 plus while 5Y4 $6.00 plus. Will this work? Does anyone have any cautionary comments? PL
:That is why you will notice the pinout of the 5Y3 and 5Y4, and 5U4, and many other octal rectifiers of this type as being very similar to the 4 pin #80 tube. The pins are spread out evenly from eachother, with a pin between to prevent arcing. If your socket is in good order, though, you shouldn't have troubles.
:T.
Well this is a fine howdy do. The schematic for this unit shows a 5Y3, I have 5Y4s ergo my post. Now I look at the set and the chassis layout diagram and it shows an 80! I checked and 80 is electrically the same as 5Y3 & 4, but now I will have to change the socket. PL
