emud rekord jr tube line up
6/12/2007 11:56:47 PMmanuel
hello just purchased an emud rekord jr.the back cover is missing. radio does not power-up the fuse is good. this radio has seven tube sockets but only six tubes. the tube that is missing is the one towards the front all the way to the right, in front of tube EAA91. i suspect the radio does not power up due to this tube being missing. any info would be appeciated thanks.
6/13/2007 5:24:48 AMJohnnysan
:hello just purchased an emud rekord jr.the back cover is missing. radio does not power-up the fuse is good. this radio has seven tube sockets but only six tubes. the tube that is missing is the one towards the front all the way to the right, in front of tube EAA91. i suspect the radio does not power up due to this tube being missing. any info would be appeciated thanks.
Any other model number?
6/13/2007 7:35:32 AMCarl T
::hello just purchased an emud rekord jr.the back cover is missing. radio does not power-up the fuse is good. this radio has seven tube sockets but only six tubes. the tube that is missing is the one towards the front all the way to the right, in front of tube EAA91. i suspect the radio does not power up due to this tube being missing. any info would be appeciated thanks.
:Any other model number?
If it is a model 196, the tubes are:
ECC85, ECH81, EBF89, Eaa91, ECL82 & EZ80.
Carl T
6/13/2007 9:48:17 AMmanuel
:::hello just purchased an emud rekord jr.the back cover is missing. radio does not power-up the fuse is good. this radio has seven tube sockets but only six tubes. the tube that is missing is the one towards the front all the way to the right, in front of tube EAA91. i suspect the radio does not power up due to this tube being missing. any info would be appeciated thanks.
::thanks for info. i guess that socket must not be used on this model. ill have to trouble shoot some more
::Any other model number?
:If it is a model 196, the tubes are:
:ECC85, ECH81, EBF89, Eaa91, ECL82 & EZ80.
:Carl T
6/15/2007 10:22:09 AMmanuel
::::hello just purchased an emud rekord jr.the back cover is missing. radio does not power-up the fuse is good. this radio has seven tube sockets but only six tubes. the tube that is missing is the one towards the front all the way to the right, in front of tube EAA91. i suspect the radio does not power up due to this tube being missing. any info would be appeciated thanks.
:::thanks for info. i guess that socket must not be used on this model. ill have to trouble shoot some more
:::i got the schematic and noticed that the empty socket is a test port. i tested tubes and found ecc85, and ech81 tubes to be bad. radio does not power up at all. no hum nothing totally dead. even with those tubes bad it should power up. any info would be appriciated thanks
:::Any other model number?
::If it is a model 196, the tubes are:
::ECC85, ECH81, EBF89, Eaa91, ECL82 & EZ80.
::Carl T
