Technical manual
6/8/2007 2:35:01 PMFrans Raes
Hello,
Someone can help me to the diagram and the technical alignment of the Philco car radio type P1426 made for Packard. I have already found a diagram at the resources on this site but the diagram is too small and too unclear.
Regards, Frans
6/8/2007 2:54:53 PMMike M
Frans,
You can try to zoom in on the schematic.
Then, if you want to print it, you can position it on your PC screen and print that view. Scroll the screen to the next area and print the view again. Once you have the whole schematic printed you can piece them together.
Mike M
:Hello,
:Someone can help me to the diagram and the technical alignment of the Philco car radio type P1426 made for Packard. I have already found a diagram at the resources on this site but the diagram is too small and too unclear.
:Regards, Frans
6/8/2007 10:56:35 PMEdd
This is an example of just about high of a detail that can be acquired without the initial document size being taken into
consideration and the incurred onset of pixelation in the transfer to electronic medium. If you need a specific area of
info / detail it might be clarified FOR you...e.g....LOOK SEE at the top left corner and the right bottom corner......
(wooeeeeee that must have been one exxxpennnnnnsive radio)....as well as checking the specified IF frequency info's
printing.
I can certainly see the shortcomings, on the original, on printings fine detail of resistance and cap values around the
crowded rf stages.
GIANT j-peg...so mag it on up, yet one step further for evaluation:
http://img87.imageshack.us/img87/2393/p1426packardautoradeeoogo6.jpg
-------------------------------------------------------------------------------------------------B/T-------------------------------------------------------------------------------------------------
:Frans,
:You can try to zoom in on the schematic.
:Then, if you want to print it, you can position it on your PC screen and print that view. Scroll the screen to the next area and print the view again. Once you have the whole schematic printed you can piece them together.
:Mike M
: :Hello,
::Someone can help me to the diagram and the technical alignment of the Philco car radio type P1426 made for Packard. I have already found a diagram at the resources on this site but the diagram is too small and too unclear.
::Regards, Frans
6/9/2007 12:00:05 PMEdd
WOOOOPSIES....seems like that GEEEE-I-ANT J-peg was even too LARGE to be data accepted, so use this referencing instead, but you will have to make a cursor pointer click on its "Please click "HERE" for full image" area.
.......Still taking note of the top left corner, 260 Kc notation at the right center, and and right bottom corner enhancements.
Re-Referenced to:
http://img04.yourpix.org/view/06.07/09/1181401906pee-1426packard_auto_raydeeoo.jpg
---------------------------------------------------------------------------------B/T--------------------------------------------------------------------------------------------------
This is an example of just about high of a detail that can be acquired without the initial document size being taken into consideration and the incurred onset of pixelation in the transfer to electronic medium. If you need a specific area of info / detail it might be clarified FOR you...e.g....take a LOOK SEE at the top left corner and the right bottom corner......
(wooeeeeee that must have been one exxxpennnnnnsive radio)....as well as checking the specified IF frequency info's printing.
I can certainly see the shortcomings, on the original, on printings fine detail of resistance and cap values that have their numerical entries crammed into nooks around the circuit crowded rf stages.
:This is an example of just about high of a detail that can be acquired without the initial document size being taken into
:consideration and the incurred onset of pixelation in the transfer to electronic medium. If you need a specific area of
:info / detail it might be clarified FOR you...e.g....LOOK SEE at the top left corner and the right bottom corner......
:(Wooeeeeee that must have been one exxxpennnnnnsive radio)....as well as checking the specified IF frequency info's
:printing.
:I can certainly see the shortcomings, on the original, on printings fine detail of resistance and cap values around the
:crowded rf stages.
:GIANT j-peg...so mag it on up, yet one step further for evaluation:
:http://img87.imageshack.us/img87/2393/p1426packardautoradeeoogo6.jpg
:-------------------------------------------------------------------------------------------------B/T-------------------------------------------------------------------------------------------------
::Frans,
::You can try to zoom in on the schematic.
::Then, if you want to print it, you can position it on your PC screen and print that view. Scroll the screen to the next area and print the view again. Once you have the whole schematic printed you can piece them together.
::Mike M
:: :Hello,
:::Someone can help me to the diagram and the technical alignment of the Philco car radio type P1426 made for Packard. I have already found a diagram at the resources on this site but the diagram is too small and too unclear.
:::Regards, Frans
6/9/2007 12:41:42 PMFrans Raes
Hello,
Many thanks for the support.
Regards,
Frans
:.......Still taking note of the top left corner, 260 Kc notation at the right center, and and right bottom corner enhancements.
:Re-Referenced to:
:http://img04.yourpix.org/view/06.07/09/1181401906pee-1426packard_auto_raydeeoo.jpg
:---------------------------------------------------------------------------------B/T--------------------------------------------------------------------------------------------------
:This is an example of just about high of a detail that can be acquired without the initial document size being taken into consideration and the incurred onset of pixelation in the transfer to electronic medium. If you need a specific area of info / detail it might be clarified FOR you...e.g....take a LOOK SEE at the top left corner and the right bottom corner......
:(wooeeeeee that must have been one exxxpennnnnnsive radio)....as well as checking the specified IF frequency info's printing.
:I can certainly see the shortcomings, on the original, on printings fine detail of resistance and cap values that have their numerical entries crammed into nooks around the circuit crowded rf stages.
::This is an example of just about high of a detail that can be acquired without the initial document size being taken into
::consideration and the incurred onset of pixelation in the transfer to electronic medium. If you need a specific area of
::info / detail it might be clarified FOR you...e.g....LOOK SEE at the top left corner and the right bottom corner......
::(Wooeeeeee that must have been one exxxpennnnnnsive radio)....as well as checking the specified IF frequency info's
::printing.
::I can certainly see the shortcomings, on the original, on printings fine detail of resistance and cap values around the
::crowded rf stages.
::GIANT j-peg...so mag it on up, yet one step further for evaluation:
::http://img87.imageshack.us/img87/2393/p1426packardautoradeeoogo6.jpg
::73's de Edd
::-------------------------------------------------------------------------------------------------B/T-------------------------------------------------------------------------------------------------
:::Frans,
:::You can try to zoom in on the schematic.
:::Then, if you want to print it, you can position it on your PC screen and print that view. Scroll the screen to the next area and print the view again. Once you have the whole schematic printed you can piece them together.
:::Mike M
::: :Hello,
::::Someone can help me to the diagram and the technical alignment of the Philco car radio type P1426 made for Packard. I have already found a diagram at the resources on this site but the diagram is too small and too unclear.
::::Regards, Frans
