Grundig 7000 radio schematic
6/7/2007 3:17:37 PMDave Froehlich
Hello All,
Can anyone see the value of C11 on this schematic?
http://oldtech.net/German/7000-USA.gif
It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
6/7/2007 3:52:02 PMMike M
Dave,
It could possibly be 22 nano farads (.022 uf)
I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
Mike M.
:Hello All,
: Can anyone see the value of C11 on this schematic?
:http://oldtech.net/German/7000-USA.gif
:It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
:Thanks,
:Dave
6/7/2007 4:31:14 PMDave Froehlich
Mike,
I used a .22 and it works fine. Another problem is that I hear nothing from the tweeters. Is that how they're supposed to work? There are plenty of high frequencies but all the sound is produced by the main speaker. What could be wrong if the tweeters aren't operational? I have replaced every paper and electrolytic capacitor in the set. I can make the tweeters make a crackle sound by trying to measure voltage or resistance on them when the radio is on. But that's about it. I know that they work without the speaker transformer, directly connected to a high voltage and output.
:Dave,
:It could possibly be 22 nano farads (.022 uf)
:I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
:Mike M.
::Hello All,
:: Can anyone see the value of C11 on this schematic?
::http://oldtech.net/German/7000-USA.gif
::It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
::Thanks,
::Dave
6/7/2007 4:38:05 PMDave Froehlich
Mike,
The 22K ohm resistor is fine. I see what looks like a 1nf or 1mf on the schematic. However it was a .001 mf capacitor that was connected to the 22K ohm resistor. Maybe someone replaced it before but maybe it should be a 1 mf capacitor.
:Mike,
: I used a .22 and it works fine. Another problem is that I hear nothing from the tweeters. Is that how they're supposed to work? There are plenty of high frequencies but all the sound is produced by the main speaker. What could be wrong if the tweeters aren't operational? I have replaced every paper and electrolytic capacitor in the set. I can make the tweeters make a crackle sound by trying to measure voltage or resistance on them when the radio is on. But that's about it. I know that they work without the speaker transformer, directly connected to a high voltage and output.
:Thanks,
:Dave
::Dave,
::It could possibly be 22 nano farads (.022 uf)
::I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
::Mike M.
:::Hello All,
::: Can anyone see the value of C11 on this schematic?
:::http://oldtech.net/German/7000-USA.gif
:::It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
:::Thanks,
:::Dave
6/7/2007 5:08:05 PMDave Froehlich
Mike,
I tried a 1mf capacitor but it was too much and it resulted in sparking. So I tried a .01 and with a slight pressure on the mesh, it works. So that's enough so it can vibrate the ribbon. I tried .1 and that was again too much. But maybe .022, .033 or .047 will work better. Maybe when the unit is screwed into place in the cabinet it will flex the front mesh so that it is close enough to the ribbon to work.
:Mike,
: The 22K ohm resistor is fine. I see what looks like a 1nf or 1mf on the schematic. However it was a .001 mf capacitor that was connected to the 22K ohm resistor. Maybe someone replaced it before but maybe it should be a 1 mf capacitor.
:Thanks,
:Dave
::Mike,
:: I used a .22 and it works fine. Another problem is that I hear nothing from the tweeters. Is that how they're supposed to work? There are plenty of high frequencies but all the sound is produced by the main speaker. What could be wrong if the tweeters aren't operational? I have replaced every paper and electrolytic capacitor in the set. I can make the tweeters make a crackle sound by trying to measure voltage or resistance on them when the radio is on. But that's about it. I know that they work without the speaker transformer, directly connected to a high voltage and output.
::Thanks,
::Dave
:::Dave,
:::It could possibly be 22 nano farads (.022 uf)
:::I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
:::Mike M.
::::Hello All,
:::: Can anyone see the value of C11 on this schematic?
::::http://oldtech.net/German/7000-USA.gif
::::It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
::::Thanks,
::::Dave
6/7/2007 5:44:11 PMDave Froehlich
Mike,
I had a little canned air so I tried that on the speakers and they worked briefly without external pressure. Now they work intermittently on their own. I am all out of canned air. I'll get more and try to get more dust out of them. Maybe it's dust that's keeping them from working.
:Mike,
: I tried a 1mf capacitor but it was too much and it resulted in sparking. So I tried a .01 and with a slight pressure on the mesh, it works. So that's enough so it can vibrate the ribbon. I tried .1 and that was again too much. But maybe .022, .033 or .047 will work better. Maybe when the unit is screwed into place in the cabinet it will flex the front mesh so that it is close enough to the ribbon to work.
:Thanks,
:Dave
::Mike,
:: The 22K ohm resistor is fine. I see what looks like a 1nf or 1mf on the schematic. However it was a .001 mf capacitor that was connected to the 22K ohm resistor. Maybe someone replaced it before but maybe it should be a 1 mf capacitor.
::Thanks,
::Dave
:::Mike,
::: I used a .22 and it works fine. Another problem is that I hear nothing from the tweeters. Is that how they're supposed to work? There are plenty of high frequencies but all the sound is produced by the main speaker. What could be wrong if the tweeters aren't operational? I have replaced every paper and electrolytic capacitor in the set. I can make the tweeters make a crackle sound by trying to measure voltage or resistance on them when the radio is on. But that's about it. I know that they work without the speaker transformer, directly connected to a high voltage and output.
:::Thanks,
:::Dave
::::Dave,
::::It could possibly be 22 nano farads (.022 uf)
::::I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
::::Mike M.
:::::Hello All,
::::: Can anyone see the value of C11 on this schematic?
:::::http://oldtech.net/German/7000-USA.gif
:::::It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
:::::Thanks,
:::::Dave
6/7/2007 6:13:11 PMEdd
Electrostatic tweeters.........they reproduce only the high sybillant audio and musical sounds. To really evaluate, disconnect your woofer and sub in a dummy load resistor of ~ proper Z to keep a loading upon the output transformer and then listen to your tweeters tweet as you up the volume......they aren't really that loud as to be easily distinguished above the main audio from the woofer / squawker.......they merely slip in a slight degree of treble enhancement.
-------------------------------------------------------------------------------------------------B/T----------------------------------------------------------------------------
:Mike,
: I had a little canned air so I tried that on the speakers and they worked briefly without external pressure. Now they work intermittently on their own. I am all out of canned air. I'll get more and try to get more dust out of them. Maybe it's dust that's keeping them from working.
:Thanks,
:Dave
::Mike,
:: I tried a 1mf capacitor but it was too much and it resulted in sparking. So I tried a .01 and with a slight pressure on the mesh, it works. So that's enough so it can vibrate the ribbon. I tried .1 and that was again too much. But maybe .022, .033 or .047 will work better. Maybe when the unit is screwed into place in the cabinet it will flex the front mesh so that it is close enough to the ribbon to work.
::Thanks,
::Dave
:::Mike,
::: The 22K ohm resistor is fine. I see what looks like a 1nf or 1mf on the schematic. However it was a .001 mf capacitor that was connected to the 22K ohm resistor. Maybe someone replaced it before but maybe it should be a 1 mf capacitor.
:::Thanks,
:::Dave
::::Mike,
:::: I used a .22 and it works fine. Another problem is that I hear nothing from the tweeters. Is that how they're supposed to work? There are plenty of high frequencies but all the sound is produced by the main speaker. What could be wrong if the tweeters aren't operational? I have replaced every paper and electrolytic capacitor in the set. I can make the tweeters make a crackle sound by trying to measure voltage or resistance on them when the radio is on. But that's about it. I know that they work without the speaker transformer, directly connected to a high voltage and output.
::::Thanks,
::::Dave
:::::Dave,
:::::It could possibly be 22 nano farads (.022 uf)
:::::I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
:::::Mike M.
::::::Hello All,
:::::: Can anyone see the value of C11 on this schematic?
::::::http://oldtech.net/German/7000-USA.gif
::::::It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
::::::Thanks,
::::::Dave
6/7/2007 10:17:32 PMDave Froehlich
Edd,
I did hear them. They sounded pretty good to me. If they would just stay on it would be great. Maybe just a little dust is getting in the way. I can hear them even if the main speaker is on. I have very good hearing. Even the main speaker has good highs.
:Electrostatic tweeters.........they reproduce only the high sybillant audio and musical sounds. To really evaluate, disconnect your woofer and sub in a dummy load resistor of ~ proper Z to keep a loading upon the output transformer and then listen to your tweeters tweet as you up the volume......they aren't really that loud as to be easily distinguished above the main audio from the woofer / squawker.......they merely slip in a slight degree of treble enhancement.
:-------------------------------------------------------------------------------------------------B/T----------------------------------------------------------------------------
::Mike,
:: I had a little canned air so I tried that on the speakers and they worked briefly without external pressure. Now they work intermittently on their own. I am all out of canned air. I'll get more and try to get more dust out of them. Maybe it's dust that's keeping them from working.
::Thanks,
::Dave
:::Mike,
::: I tried a 1mf capacitor but it was too much and it resulted in sparking. So I tried a .01 and with a slight pressure on the mesh, it works. So that's enough so it can vibrate the ribbon. I tried .1 and that was again too much. But maybe .022, .033 or .047 will work better. Maybe when the unit is screwed into place in the cabinet it will flex the front mesh so that it is close enough to the ribbon to work.
:::Thanks,
:::Dave
::::Mike,
:::: The 22K ohm resistor is fine. I see what looks like a 1nf or 1mf on the schematic. However it was a .001 mf capacitor that was connected to the 22K ohm resistor. Maybe someone replaced it before but maybe it should be a 1 mf capacitor.
::::Thanks,
::::Dave
:::::Mike,
::::: I used a .22 and it works fine. Another problem is that I hear nothing from the tweeters. Is that how they're supposed to work? There are plenty of high frequencies but all the sound is produced by the main speaker. What could be wrong if the tweeters aren't operational? I have replaced every paper and electrolytic capacitor in the set. I can make the tweeters make a crackle sound by trying to measure voltage or resistance on them when the radio is on. But that's about it. I know that they work without the speaker transformer, directly connected to a high voltage and output.
:::::Thanks,
:::::Dave
::::::Dave,
::::::It could possibly be 22 nano farads (.022 uf)
::::::I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
::::::Mike M.
:::::::Hello All,
::::::: Can anyone see the value of C11 on this schematic?
:::::::http://oldtech.net/German/7000-USA.gif
:::::::It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
:::::::Thanks,
:::::::Dave
6/8/2007 5:12:25 PMDave Froehlich
Edd.
Even when "cleaned" (using canned air) , they always require slight pressure on the screen in or they will be silent. Sometimes they stay on for a few minutes but then need pressure to continue working.
:Edd,
: I did hear them. They sounded pretty good to me. If they would just stay on it would be great. Maybe just a little dust is getting in the way. I can hear them even if the main speaker is on. I have very good hearing. Even the main speaker has good highs.
:Thanks,
:Dave
::Electrostatic tweeters.........they reproduce only the high sybillant audio and musical sounds. To really evaluate, disconnect your woofer and sub in a dummy load resistor of ~ proper Z to keep a loading upon the output transformer and then listen to your tweeters tweet as you up the volume......they aren't really that loud as to be easily distinguished above the main audio from the woofer / squawker.......they merely slip in a slight degree of treble enhancement.
::73's de Edd
::-------------------------------------------------------------------------------------------------B/T----------------------------------------------------------------------------
:::Mike,
::: I had a little canned air so I tried that on the speakers and they worked briefly without external pressure. Now they work intermittently on their own. I am all out of canned air. I'll get more and try to get more dust out of them. Maybe it's dust that's keeping them from working.
:::Thanks,
:::Dave
::::Mike,
:::: I tried a 1mf capacitor but it was too much and it resulted in sparking. So I tried a .01 and with a slight pressure on the mesh, it works. So that's enough so it can vibrate the ribbon. I tried .1 and that was again too much. But maybe .022, .033 or .047 will work better. Maybe when the unit is screwed into place in the cabinet it will flex the front mesh so that it is close enough to the ribbon to work.
::::Thanks,
::::Dave
:::::Mike,
::::: The 22K ohm resistor is fine. I see what looks like a 1nf or 1mf on the schematic. However it was a .001 mf capacitor that was connected to the 22K ohm resistor. Maybe someone replaced it before but maybe it should be a 1 mf capacitor.
:::::Thanks,
:::::Dave
::::::Mike,
:::::: I used a .22 and it works fine. Another problem is that I hear nothing from the tweeters. Is that how they're supposed to work? There are plenty of high frequencies but all the sound is produced by the main speaker. What could be wrong if the tweeters aren't operational? I have replaced every paper and electrolytic capacitor in the set. I can make the tweeters make a crackle sound by trying to measure voltage or resistance on them when the radio is on. But that's about it. I know that they work without the speaker transformer, directly connected to a high voltage and output.
::::::Thanks,
::::::Dave
:::::::Dave,
:::::::It could possibly be 22 nano farads (.022 uf)
:::::::I've seen other schematics where the ECH81 cathode is bypassed by 10 nano farads in a mixer ckt.
:::::::Mike M.
::::::::Hello All,
:::::::: Can anyone see the value of C11 on this schematic?
::::::::http://oldtech.net/German/7000-USA.gif
::::::::It looks like a .22 mf capacitor but it's so illegable that I'm not sure. The value on the actual capacitor is also almost completely illegable too. It's on the cathode so I don't think it will affect the audio much if it's a .022, .1 or .22. I'm almost done with the restoration so I'm using a .22. The referenced schematic looks similar to the chassis I'm working on, which only has a serial number on it. The serial number starts with 1032 but doubt that that's a model numbe. It seems more like the Grundig 7000 to me.
::::::::Thanks,
::::::::Dave
6/10/2007 9:10:47 AMWalterh
:Edd.
: Even when "cleaned" (using canned air) , they always require slight pressure on the screen in or they will be silent. Sometimes they stay on for a few minutes but then need pressure to continue working.
Hi
These speakers are built with a metal coated foil that is contacted by a copper foil. To ensure proper contact, a small foam part was underlayed. That foam disintegrated over time. Simply open the tweeter and replace the foam. Be careful when soldering on the contacts - the foil is heat sensitive.
Kind regards, Walter Haring, Switzerland
6/10/2007 9:05:00 AMWalterh
:Hello All,
:Thanks,
:Dave
Hi Dave
It's a 22nF. I've sent a better readable schematic.
Kind regards from Switzerland, Walter Haring
6/10/2007 2:48:48 PMDave Froehlich
Walter,
Thanks for the more readable schematic. Another problem I'm having with this radio, which is actually the Grundig 1036, is that someone removed the chassis and speakers from the cabinet and they want me to put it back together. I don't know how the tweeters, are held in with all those brackets. Do you have a picture of this as well? I think I can figure it out from a picture.
Thanks again,
::Hello All,
::Thanks,
::Dave
:Hi Dave
:It's a 22nF. I've sent a better readable schematic.
:Kind regards from Switzerland, Walter Haring
