If it wasn't for 6G6 looks like something Philco would make. Octal 35Z5 along with loctal tubes.
Since the radio has a 6G6 must also have a series filament dropping resistor? More common output tube would be 50L6 or 50A5.
:Need help ID ing radio or chassis.It is BC/SW with 6 tubes.The tube lineup is:::35z5,6G6,7C6,7A8 and two(2) 7B7..the radio doesn't have any tags or numbers....It has 3 knobs with a gold colored square dial...
Good to hear it's operating. I don't know how they power filaments but if directly across the AC line you will have a hot series resistor dropping voltage. If that's the case 50L6 can replace the 6G6 and the resistor can be eliminated.
::Hi
:: If it wasn't for 6G6 looks like something Philco would make. Octal 35Z5 along with loctal tubes.
:: Since the radio has a 6G6 must also have a series filament dropping resistor? More common output tube would be 50L6 or 50A5.
:That's is the tube comp....The more I look @ this radio the more I think it might be a project kit or a home brew....Got it up and running and it is sensitive on both BC and SW however with a bit of static....
:::Need help ID ing radio or chassis.It is BC/SW with 6 tubes.The tube lineup is:::35z5,6G6,7C6,7A8 and two(2) 7B7..the radio doesn't have any tags or numbers....It has 3 knobs with a gold colored square dial...
