To close the eye of a 6E5 you need -8 volts on the AVC line. Has the radio been aligned? Do you have an antenna?
Measure AVC voltage on pin #3 of your 6E5.
:My 1930"s Grunow console has a tuning eye with a 6E5 tube that only moves slightly on strong stations, It has been recapped and has good reception, any idea what would be keeping the eye from being more sensitive to signal strength?
:Dave
: To close the eye of a 6E5 you need -8 volts on the AVC line. Has the radio been aligned? Do you have an antenna?
: Measure AVC voltage on pin #3 of your 6E5.
::My 1930"s Grunow console has a tuning eye with a 6E5 tube that only moves slightly on strong stations, It has been recapped and has good reception, any idea what would be keeping the eye from being more sensitive to signal strength?
One more thing. There should be a 1 meg resistor between pin #2 and #4. If this resistor has gone way up in value you won't have much movement. Sometimes this resistor is built into the eye tube socket.
:Any chance someone used a 6U5 or 6G5 tube. These aren't as sensitive.
::Dave
:: To close the eye of a 6E5 you need -8 volts on the AVC line. Has the radio been aligned? Do you have an antenna?
:: Measure AVC voltage on pin #3 of your 6E5.
:::My 1930"s Grunow console has a tuning eye with a 6E5 tube that only moves slightly on strong stations, It has been recapped and has good reception, any idea what would be keeping the eye from being more sensitive to signal strength?
