How do you get those meters apart with destroying them?
It appears to me that they are sealed.
Any help will be appreciated.
:They're not sealed, but there might be a rubber gasket that's sticking, I don't recall.
Hickok meters don't age gracefully. It's common for their internal parts to corrode. The zero adjuster can lose continuity to the hairspring that carries current to the moving coil. You can look at it and swear that two metal parts so close together can't be insulated, but they are.
The meter looked like it was trying to mildue. I've seen other items mildew out there. It is insulated really tight, and sometimes that happens. I noticed the humidity this spring has been above 90%.
If I get this thing working, I'll keep it in a dryer place, or at least up off the floor. But it's a buger as I have no shelf wide enough to lay it on... Oh well.
:There are a couple of places that will rebuild meters; the one I remember is Ram (couldn't tell you where, but I've seen recommendations for their work). If you do that, it would be best not to try opening it, though I think it could be pried apart by careful use of some single-edge razor blades.
:Hickok meters don't age gracefully. It's common for their internal parts to corrode. The zero adjuster can lose continuity to the hairspring that carries current to the moving coil. You can look at it and swear that two metal parts so close together can't be insulated, but they are.
