:Dave,
:I did one of those beasts a while back, and as I remember it there were three electrolytics of 50mf each. And Maybe one other, but nothing like what you found in the set you have. I do remember paralleling up several, probably 47s and 10s to get 57s. I worked in any event.
:Good luck,
:Jim
High value electrolytics were used in transistor radios but at low voltage. Measure voltage across the cap. Most likely 2000 mf @ 25 volts will work. These high value, low voltage caps can usually be found at Radio Shack.
Transistor radios draw more current but operate on low voltage, need more capacity. Your 100 mf @ 160 volts is a tube circuit value.
:Jim,
: This is a solid state set from 1965. If that's all it is what voltage are the filter capacitors? I have a 100 mf at 160 volts. Could that be sufficient? I wonder why there are such large capacitor values there.
:Thanks,
:Dave
::Dave,
::I did one of those beasts a while back, and as I remember it there were three electrolytics of 50mf each. And Maybe one other, but nothing like what you found in the set you have. I do remember paralleling up several, probably 47s and 10s to get 57s. I worked in any event.
::Good luck,
::Jim
:Dave
: High value electrolytics were used in transistor radios but at low voltage. Measure voltage across the cap. Most likely 2000 mf @ 25 volts will work. These high value, low voltage caps can usually be found at Radio Shack.
: Transistor radios draw more current but operate on low voltage, need more capacity. Your 100 mf @ 160 volts is a tube circuit value.
::Jim,
:: This is a solid state set from 1965. If that's all it is what voltage are the filter capacitors? I have a 100 mf at 160 volts. Could that be sufficient? I wonder why there are such large capacitor values there.
::Thanks,
::Dave
:::Dave,
:::I did one of those beasts a while back, and as I remember it there were three electrolytics of 50mf each. And Maybe one other, but nothing like what you found in the set you have. I do remember paralleling up several, probably 47s and 10s to get 57s. I worked in any event.
:::Good luck,
:::Jim
:Norm,
: I'll try a 2200 mf capacitor.
:Thanks,
:Dave
::Dave
:: High value electrolytics were used in transistor radios but at low voltage. Measure voltage across the cap. Most likely 2000 mf @ 25 volts will work. These high value, low voltage caps can usually be found at Radio Shack.
:: Transistor radios draw more current but operate on low voltage, need more capacity. Your 100 mf @ 160 volts is a tube circuit value.
:::Jim,
::: This is a solid state set from 1965. If that's all it is what voltage are the filter capacitors? I have a 100 mf at 160 volts. Could that be sufficient? I wonder why there are such large capacitor values there.
:::Thanks,
:::Dave
::::Dave,
::::I did one of those beasts a while back, and as I remember it there were three electrolytics of 50mf each. And Maybe one other, but nothing like what you found in the set you have. I do remember paralleling up several, probably 47s and 10s to get 57s. I worked in any event.
::::Good luck,
::::Jim
