----------------------------------------------------------BT----------------------------------------------------------
:Hello All,
: I had the idler rebuilt and seem to have forgotten how it all goes back together. A picture would help.
:Thanks,
:Dave
:You got's it...all 2.5 megglingbits of it !
:----------------------------------------------------------BT----------------------------------------------------------
::Hello All,
:: I had the idler rebuilt and seem to have forgotten how it all goes back together. A picture would help.
::Thanks,
::Dave
:Edd,
: That's the correct SAMs for the VM 1228 but it turns out that somone "turned the tables on us" and put another VM turntable in that base. The one I'm working on has both sections of the idler the same diameter. The assembly that the idler goes on, installs upside down, I seem to remember.
:Thanks,
:Dave
::You got's it...all 2.5 megglingbits of it !
::73's de Edd
::----------------------------------------------------------BT----------------------------------------------------------
:::Hello All,
::: I had the idler rebuilt and seem to have forgotten how it all goes back together. A picture would help.
:::Thanks,
:::Dave
:Edd,
: I have it working. I even had the original VM service data, and there's no model 1228. All the models covered have idlers with much larger diameters. There must be a separate set of service data for the 1228 somewhere. But I don't need it anymore.
:Thanks,
:Dave
::Edd,
:: That's the correct SAMs for the VM 1228 but it turns out that somone "turned the tables on us" and put another VM turntable in that base. The one I'm working on has both sections of the idler the same diameter. The assembly that the idler goes on, installs upside down, I seem to remember.
::Thanks,
::Dave
:::You got's it...all 2.5 megglingbits of it !
:::73's de Edd
:::----------------------------------------------------------BT----------------------------------------------------------
::::Hello All,
:::: I had the idler rebuilt and seem to have forgotten how it all goes back together. A picture would help.
::::Thanks,
::::Dave
:Hello Again All,
: Somehow, the overarm won't stay up high enough to detect a single record, so the turntable shuts off sometimes after dropping a rectord. Has anyone had this problem before? What can I do about it? I suggested bending the over arm or putting a rubber bumper on it's under side, which would solve the problem. But its owner says that this fix is unacceptable, and will not allow me to do these things. What should I do?
:Thanks,
:Dave
::Edd,
:: I have it working. I even had the original VM service data, and there's no model 1228. All the models covered have idlers with much larger diameters. There must be a separate set of service data for the 1228 somewhere. But I don't need it anymore.
::Thanks,
::Dave
:::Edd,
::: That's the correct SAMs for the VM 1228 but it turns out that somone "turned the tables on us" and put another VM turntable in that base. The one I'm working on has both sections of the idler the same diameter. The assembly that the idler goes on, installs upside down, I seem to remember.
:::Thanks,
:::Dave
::::You got's it...all 2.5 megglingbits of it !
::::73's de Edd
::::----------------------------------------------------------BT----------------------------------------------------------
:::::Hello All,
::::: I had the idler rebuilt and seem to have forgotten how it all goes back together. A picture would help.
:::::Thanks,
:::::Dave
::Hello All,
::Thanks,
::Dave
