TF
What type of plug? 4 and 5 pin plugs were popular. In many cases the base of an old tube can be used as a speaker plug,
:Does anyone make/sell speaker plugs? The kind used on Philco, RCA, Zenith? Maybe there is a substitute? Any help is appreciated, as always.
:TF
TF
:Terry
: What type of plug? 4 and 5 pin plugs were popular. In many cases the base of an old tube can be used as a speaker plug,
::Does anyone make/sell speaker plugs? The kind used on Philco, RCA, Zenith? Maybe there is a substitute? Any help is appreciated, as always.
::TF
Does an 80 tube fit the speaker socket? (There should be an 80 in your radio to try.) If so I can send you a 4 pin tube base.
:Norm, right now I need a Philco 4-prong.
:TF
::Terry
:: What type of plug? 4 and 5 pin plugs were popular. In many cases the base of an old tube can be used as a speaker plug,
:::Does anyone make/sell speaker plugs? The kind used on Philco, RCA, Zenith? Maybe there is a substitute? Any help is appreciated, as always.
:::TF
Sorry for the delay in replying but I had to locate an 80.
No, it doesn't fit. I am also looking for the speaker female plugs (3 and 4 pin). Any ideas?
Terry F
:Terry
: Does an 80 tube fit the speaker socket? (There should be an 80 in your radio to try.) If so I can send you a 4 pin tube base.
::Norm, right now I need a Philco 4-prong.
::TF
:::Terry
::: What type of plug? 4 and 5 pin plugs were popular. In many cases the base of an old tube can be used as a speaker plug,
::::Does anyone make/sell speaker plugs? The kind used on Philco, RCA, Zenith? Maybe there is a substitute? Any help is appreciated, as always.
::::TF
If spacing is wrong but pin size right try breaking an old tube base. You could use individual pins or mold your own using the pins?
Might be able to use a tube socket or the contacts for the female side?
If you don't have either side I would use a 4 pin tube base and socket.
:Norm,
:Sorry for the delay in replying but I had to locate an 80.
:No, it doesn't fit. I am also looking for the speaker female plugs (3 and 4 pin). Any ideas?
:Terry F
::Terry
:: Does an 80 tube fit the speaker socket? (There should be an 80 in your radio to try.) If so I can send you a 4 pin tube base.
:::Norm, right now I need a Philco 4-prong.
:::TF
::::Terry
:::: What type of plug? 4 and 5 pin plugs were popular. In many cases the base of an old tube can be used as a speaker plug,
::::Norm
:::::Does anyone make/sell speaker plugs? The kind used on Philco, RCA, Zenith? Maybe there is a substitute? Any help is appreciated, as always.
:::::TF
