Schematic Freed Eisemann NR5
7/24/2000 2:03:46 AMDave Robinson
Looking for copy of schematic for Freed Eisemann model NR5. Have one w/o tubes.. need to find list of the 5 tubes. Email Please..
7/24/2000 10:17:33 AMDon Black
Hi Dave, I've emaied the schematic for your Freed NR5. It's not as clear as I'd like but about normal for the vintage. It doesn't indicate the tubes on the schematic but the A supply voltage is 6 volts for all tubes, it will use 01A tubes in all positions. Later models used 01A's with a 71A output tube but your set uses the same C- bias voltage for the driver and output tube, the 71A would require a higher bias voltage and your set is a couple of years too old for the 71A anyway. They will all be 01A's. Good Luck, Don Black.
: Looking for copy of schematic for Freed Eisemann model NR5. Have one w/o tubes.. need to find list of the 5 tubes. Email Please..
