HY75 is a small transmitting tube.
http://www.r-type.org/exhib/aad0213.htm
It's a VHF triode with 6.3 volt @ 2.5 amp filament. Gain of 10.
::Has anyone heard of this transceiver, it is called an ultra shortwave transceiver, it contains a 7F7 locktal, one empty octal socket, a Hytron HY75, and a Hytron HY615. Any ideas? It is small for a transceiver and uses an ouboard power supply coneected via a six pin connector but this is missing and the radio is quite compact, the dials use the old 20's 0-100 scale.
::I am looking for a datasheet of the HY75 tube. Has anyone got any?
:Hi
: HY75 is a small transmitting tube.
:http://www.r-type.org/exhib/aad0213.htm
: It's a VHF triode with 6.3 volt @ 2.5 amp filament. Gain of 10.
: Norm
:::Has anyone heard of this transceiver, it is called an ultra shortwave transceiver, it contains a 7F7 locktal, one empty octal socket, a Hytron HY75, and a Hytron HY615. Any ideas? It is small for a transceiver and uses an ouboard power supply coneected via a six pin connector but this is missing and the radio is quite compact, the dials use the old 20's 0-100 scale.
:::I am looking for a datasheet of the HY75 tube. Has anyone got any?
Look in The Radio Amateur Handbook from around 1950. They show spec's for HY75.
:I have found only bits of info but I neet a pdf datasheet. It is difficult to find...
::Hi
:: HY75 is a small transmitting tube.
::http://www.r-type.org/exhib/aad0213.htm
:: It's a VHF triode with 6.3 volt @ 2.5 amp filament. Gain of 10.
:: Norm
::::Has anyone heard of this transceiver, it is called an ultra shortwave transceiver, it contains a 7F7 locktal, one empty octal socket, a Hytron HY75, and a Hytron HY615. Any ideas? It is small for a transceiver and uses an ouboard power supply coneected via a six pin connector but this is missing and the radio is quite compact, the dials use the old 20's 0-100 scale.
::::I am looking for a datasheet of the HY75 tube. Has anyone got any?
