I see on other amplifier schematics that cathode bypass caps are sometimes used in push pull amplifiers.
.. so..
Is there something different about push-pull cathode biasing that I'm over looking that caused me NOT to hear any audible difference when adding that cap?
Is there... something in the biasing or circuit design that precludes that noticable volume boost with a cathode bypass cap?
A condenser is always a bonus, but isn't really necessary. If each tube has its own resistor, on the other hand, a condenser on each resistor may help.
In theory Thomas is correct. A cathode bypass capacitor isn't needed. In actual practice you will find that a capacitor bypassing the cathode resistor still increases volume and helps low frequency response. Some of this is due to tubes not being matched.
:Or, rather, since tubes only allow current in one direction, push-pull isn't really the correct term. When one is pushing, the other isn't. As one increases in conduction, the other one dies down, since it's receiving the signal out of phase. Neither one pulls, though.
In the ST-70, each pair of p-p output tubes share a precision 15.6-ohm cathode resistor, so when the grid bias is correct, there will be 1.56V DC measured across the cathode resistor.
OK, so what's my point? I tend to think that bypassing the cathode resistor in this case might goof-up setting the fixed grid bias? Comments?
Doug
:Hi Peter
: In theory Thomas is correct. A cathode bypass capacitor isn't needed. In actual practice you will find that a capacitor bypassing the cathode resistor still increases volume and helps low frequency response. Some of this is due to tubes not being matched.
In Peter's and my case, though, the resistor we are talking about is definitely used for bias. My two push-pull radios must have some fairly well matched tubes, because I cannot discern a difference with or without a condenser. However, with one tube pulled, I can, but that's because it's going back to single ended output.
:Vintage tube-type, push-pull amps, e.g. my stereo Dynaco ST-70, have a small-value cathode resistor which is unbypassed. The purpose of the resistor is not to provide grid bias (which is fixed) - but rather to provide a convenient way to measure cathode current. The cathode current needs to be measured when setting the fixed grid bias.
:In the ST-70, each pair of p-p output tubes share a precision 15.6-ohm cathode resistor, so when the grid bias is correct, there will be 1.56V DC measured across the cathode resistor.
:OK, so what's my point? I tend to think that bypassing the cathode resistor in this case might goof-up setting the fixed grid bias? Comments?
:Doug
::Hi Peter
:: In theory Thomas is correct. A cathode bypass capacitor isn't needed. In actual practice you will find that a capacitor bypassing the cathode resistor still increases volume and helps low frequency response. Some of this is due to tubes not being matched.
In a push-pull circuit, one tube is conducting while the other is not. As a signal wave passes through center, both tubes conduct half of what they would or would not if the wave was at its peak or trough. The two tubes balance eachother, since they are doing the exact opposite of eachother. If one of the tubes conducts slightly better than the other, this balance may be thrown off slightly. Under ideal circumstances, voltage fluctuation will not occur at the cathode bias resistor, if the resistor serves both tubes.
