Need 117Z6 tube
5/6/2007 7:24:52 PMdel in MN
Anybody have one to spare for Zenith TO. Thanks
5/6/2007 9:20:15 PMMark
Just curious are you the same Del that was at a northern WI amature radio swapfest on 5-5-07?
Don't know if I have the tube but I'll check my spare stuff when I can get a chance to crawl into my attic.
MRO
:Anybody have one to spare for Zenith TO. Thanks
5/7/2007 7:39:24 AMddelby8652@peoplepc.com
:Just curious are you the same Del that was at a northern WI amature radio swapfest on 5-5-07?
:Don't know if I have the tube but I'll check my spare stuff when I can get a chance to crawl into my attic.
:MRO
::Anybody have one to spare for Zenith TO. Thanks
5/7/2007 2:10:23 PMNorm Leal
Hi
117Z6's sell for around $5.00. They can be purchased from Radio Daze, www.radiodaze.com and AES, www.tubesandmore.com.
117Z6 is a full wave rectifier but each section is connected in parallel. You can relace the tube with a single 1N4004 - 1N4007 silicon diode. A 47 ohm resistor should be added in series.
::Just curious are you the same Del that was at a northern WI amature radio swapfest on 5-5-07?
::Don't know if I have the tube but I'll check my spare stuff when I can get a chance to crawl into my attic.
::MRO
:::Anybody have one to spare for Zenith TO. Thanks
5/7/2007 2:21:54 PMRadiodoc
And the diode and resistor can be wired into the base of an old tube socket and plugged in thus not modifiying the radio
:Hi
: 117Z6's sell for around $5.00. They can be purchased from Radio Daze, www.radiodaze.com and AES, www.tubesandmore.com.
: 117Z6 is a full wave rectifier but each section is connected in parallel. You can relace the tube with a single 1N4004 - 1N4007 silicon diode. A 47 ohm resistor should be added in series.
:::Just curious are you the same Del that was at a northern WI amature radio swapfest on 5-5-07?
:::Don't know if I have the tube but I'll check my spare stuff when I can get a chance to crawl into my attic.
:::MRO
::::Anybody have one to spare for Zenith TO. Thanks
