Tubes with molybdenum/gold filament.
7/20/2000 7:00:09 AMMarcello D'Elia
Does Anybody know a kind of tube (or termoionic valve) wich is based on filaments (anode?) of molybdenum coated with gold?
If so, could I have any reference about it?
Regards
Marcello D'Elia - Italy
7/20/2000 8:58:17 AMJohn McPherson
You probably will not find much molybdenum in a tube (valve), nor was gold much used in their production, and neither of which would be used for a filament.
Filament types typically use pure Tungsten, or Thoriated Tungsten or in newer types a Nickel alloy coated with alkaline "Rare Earth" compounds.
Gold and Molybdenum are very soft metals, and would probably not support their own weight if heated to the temperatures of the pure Tungsten filaments. At a minimum they would have the potential to stretch and possibly short things out. Molybdenum has been used as a friction reducing additive because of the softness of the material, and it's ability to act as a lubricant at higher temperatures.
This is not to say that deForest, Flemming, Marconi, and Edison did not experiment with those materials, just that it is not very likely. Edison's experiments with various materials for his light bulbs, so his work laid out a starting point for Lee deForest, Flemming, Marconi, and others to build on, and they knew what characteristics they needed to make things work.
Gold and Molybdenum also do not form oxides reaily, and their reaction potentials are low, so they are not "free electron emitters", that you would need for a filament, or a heater for that matter.
RCA does list Molybdenum as one of the materials that are used in grid wires, but they do not specify which tubes, and again, Molybdenum is a very soft metal, so it is doubtful it was widely used even there.
You may have heard some erroneous speculations by some Gold hunters, which would be bad for the tube market as you would have speculators running prices up, then essentially removing them (tubes/valves) from the market place where they would be destroyed for no good reason; and well out of the reach of radio restorers.
I will however gladly sell them my duds, and I am sure many people would contribute their duds too, but there just is not any amount of gold- regardless of spot prices of gold- that would be of real use in a tube that would have been used in real amounts. One would find more gold as an impurity in eutectic solders.
If you do hear something that sounds substantial, please let us know.
: Does Anybody know a kind of tube (or termoionic valve) wich is based on filaments (anode?) of molybdenum coated with gold?
: If so, could I have any reference about it?
: Regards
: Marcello D'Elia - Italy
1/18/2001 3:30:07 PMjeremy
: You probably will not find much molybdenum in a tube (valve), nor was gold much used in their production, and neither of which would be used for a filament.
: Filament types typically use pure Tungsten, or Thoriated Tungsten or in newer types a Nickel alloy coated with alkaline "Rare Earth" compounds.
: Gold and Molybdenum are very soft metals, and would probably not support their own weight if heated to the temperatures of the pure Tungsten filaments. At a minimum they would have the potential to stretch and possibly short things out. Molybdenum has been used as a friction reducing additive because of the softness of the material, and it's ability to act as a lubricant at higher temperatures.
: This is not to say that deForest, Flemming, Marconi, and Edison did not experiment with those materials, just that it is not very likely. Edison's experiments with various materials for his light bulbs, so his work laid out a starting point for Lee deForest, Flemming, Marconi, and others to build on, and they knew what characteristics they needed to make things work.
: Gold and Molybdenum also do not form oxides reaily, and their reaction potentials are low, so they are not "free electron emitters", that you would need for a filament, or a heater for that matter.
: RCA does list Molybdenum as one of the materials that are used in grid wires, but they do not specify which tubes, and again, Molybdenum is a very soft metal, so it is doubtful it was widely used even there.
: You may have heard some erroneous speculations by some Gold hunters, which would be bad for the tube market as you would have speculators running prices up, then essentially removing them (tubes/valves) from the market place where they would be destroyed for no good reason; and well out of the reach of radio restorers.
: I will however gladly sell them my duds, and I am sure many people would contribute their duds too, but there just is not any amount of gold- regardless of spot prices of gold- that would be of real use in a tube that would have been used in real amounts. One would find more gold as an impurity in eutectic solders.
: If you do hear something that sounds substantial, please let us know.
: : Does Anybody know a kind of tube (or termoionic valve) wich is based on filaments (anode?) of molybdenum coated with gold?
: : If so, could I have any reference about it?
: : Regards
: : Marcello D'Elia - Italy
7/20/2000 9:57:26 AMDon Black
Hello Marcello, John has covered it pretty well. I don't know why they used molybdenum but I'd speculate it might be to reduce grid emission, the opposite conditions for a cathode. Some premium quality tubes used gold plating on the base pins. I'll be interested to see any responses from people who worked on tube design. Cheers, Don Black.
: Regards
7/20/2000 11:28:46 AMNorm Leal
Hi Marcello
Western Electric made most of their tubes with molybdenum grids held with nickel side rails. Western Electric gold plated these grid laterals in their premium tubes such as 350A and 350B.
RCA used molybdeum for plates and grids, even in transmitting tubes. It was easier to work with and degas than tungsten. Usually fins were added to molybdeum plates and they were roughened by carborundum blasting to improve heat radiation.
: Regards
9/16/2000 5:03:50 PMcalvin
: Regards
9/16/2000 5:13:49 PMcalvin
: tubes are thermionic valves. gold was applied to some tube grids that either handled high current and wer therefore subject to increased miller effect (grid capacitance) or tube in sensitive applications for radio frequency wich mandated low grid capacitance (miller effect) sorry golddiggers but it is only a few atoms thick so you couldent realy get enough gold to deflect the scale on the most sensitive tripple beam from ten tubes combined. the gold was sputtered onto the grid electrochemically in the most economical fasion possible and not much expence on raw gold was spent. the process of application was what money would have been spent on from a manufacturing stand point.
