This radio loses voltage as it runs. Starts out with 6 VDC going in, drops to about 2.5 volts, warms up and runs about 4.8 volts, and then drops down to under 3 v and the audio goes away gradually under 2.75v. Takes about 5 minutes to drop off. Any suggestions. This model has a spark plate where the 6V enters. Thanks
I think that the only reason for the battery eleminator Voltage drop could only be caused by excessive current draw. Excessive current means something is getting hot. I am suspecting a filter capacitor if you haven't changed them yet, and if they are getting hot from leakage, they can build up a dangerous amount of pressure, and give one a face full of hot electrolyte. If you have recapped, check again for proper polarity. A capacitor installed backward will conduct electricity, and act just like a leaky one. Are resistors getting too hot? Remove your vibrator and let just the filaments run for a while, and see what happens. There is a buffer condenser across the secondary of the power transformer, like a 1.2 KV fella. Check this guy, or better replace with a new one. Do you have the old vibrator? Try it and see what happens. These are just some random thoughts, things I would try if I were fixing the radio. Sometimes you fix radios just trying off-the-wall ideas, just doing something and seeing something happen that shouldn't happen.
Guys,
Are we sure the ARBE eliminator can supply enough current to properly operate the radio. If the ARBE III is being used it is rated 1.25 - 6.5 volts at 3A. The schematic shows the radio being fused at 10A. I would suspect the radio draws some measure over 3A possibly shuting down the output of the eliminator from overload.
Good idea there, Doc! The delay could be caused by temperature protection of the output transistors in the eliminator. We need to know what is the measured input current of the radio when it is first swithced on and working properly.
::::As a starter , would you try this analysis. Specifically, to see if the problem might be audio output / circuit related.
::::relevant to the potential other options of power supply or DC leakage therein related. It will be dependent upon the disabling of the output tubes so you will no longer be able to hear the audio.(However, if you have a scope you might watch it upon the plate circuitry of the AF driver stage, should you be feeding in a stable 400 / 1000 ~ modulated signal from a generator...or even AC meter it..in case of the later stable modulated sourcing).
::::Initilly, trace down your centertap of the output transformer and tack in a 10k 10 watt wirewound to ground from that buss line and then unplug your two AF output tubes and have your metering conected to that B+ point and fire up the set and then clip on and take a B+ DC reading just as soon as the voltage initially stabilizes. Theeeeeeen twidddle your thumbs until "THE" prescribed time approaches, and see if the voltage has / had started dropping. [Also sneak a peek at the your Battery eliminator Power units ammeter, if it has current metering, both at power start and onset of the trouble..if it even occurs this time] This will then differentiate that the prime problem was not related to a gradiated bias shift in the current hungry AF output stage.
::::We are now waiting for your findings.
::::73's de Edd
:::I think that the only reason for the battery eleminator Voltage drop could only be caused by excessive current draw. Excessive current means something is getting hot. I am suspecting a filter capacitor if you haven't changed them yet, and if they are getting hot from leakage, they can build up a dangerous amount of pressure, and give one a face full of hot electrolyte. If you have recapped, check again for proper polarity. A capacitor installed backward will conduct electricity, and act just like a leaky one. Are resistors getting too hot? Remove your vibrator and let just the filaments run for a while, and see what happens. There is a buffer condenser across the secondary of the power transformer, like a 1.2 KV fella. Check this guy, or better replace with a new one. Do you have the old vibrator? Try it and see what happens. These are just some random thoughts, things I would try if I were fixing the radio. Sometimes you fix radios just trying off-the-wall ideas, just doing something and seeing something happen that shouldn't happen.
:::Lewis
::Guys,
::Are we sure the ARBE eliminator can supply enough current to properly operate the radio. If the ARBE III is being used it is rated 1.25 - 6.5 volts at 3A. The schematic shows the radio being fused at 10A. I would suspect the radio draws some measure over 3A possibly shuting down the output of the eliminator from overload.
::Radiodoc
:Good idea there, Doc! The delay could be caused by temperature protection of the output transistors in the eliminator. We need to know what is the measured input current of the radio when it is first swithced on and working properly.
:Lewis
I think you will be very pleased with the results. As I said, those old car radios were power hungry monsters.
Don't forget to let us know the results you get when you try the radio on a 6 volt car battery.
:: I am going to use a 6v car battery fused to 10 amps and see what happens. A local fellow told me the ARBE 3 does not do well on these old radios as a power supply. Thanks for confirming what he said. Best wishes.
:I think you will be very pleased with the results. As I said, those old car radios were power hungry monsters.
:Lewis
