::Often I'll just lift only one end and then slide small gauge heat shrink sleeving over them.
::I don't heat them up, just leave them. Though a heat gun would work fine.
::Saves a lot of time .
:If the insulation is still in place and just cracked you can paint it with liquid insulation (available at WalMart) or PVC pipe adhesive (clear). Both are PVC based in solvent.
Peter:
Back in my airline days, I had occasion to work on strobe lights, they work about 400 Volts, and are insulated with Teflon. At the places where the insulation ended, you could see some deteroration on some of the older ones. We concluded that it was a small amount of ozone produced by the high Voltage that was attacking the teflon. I guess it would be worse for rubber. While on the subject of capacitors (they flash the lights, you know) we would slowly put rated Voltage on the caps, usually 450 Volts, and measure the leakage after a few minutes. I forgot the limits, but the good ones didn't leak (<5 MA.), while the bad ones took off like a skyrocket long before rated Voltage. I don't remember the limit, because I never used it. Good was real good, bad was horrid, just like a little girl of nursery rhyme fame.
