:I recently bought an cosmetically excellent Royal 7000. The seller shipped it with inadequate cushioning material. It now has what appears to be an intermittent connection somewhere. It receives great on the FM band. For the BC or SW bands, I can only get reception (or static for that matter) if I apply some pressure to the bandswitch or tuning knobs. Seems that by doing so I am restoring a connection somewhere. Has anyone seen this issue before in a Royal 7000? Or can you suggest any likely places to check first or any good techniques to help isolate the problem?. Thanks much.
I've seen many AM problems caused by the RF gain switch and control.
Should you need some other information you may check at:
http://www.transoceanic.nostalgiaair.org/
