thanks,
Frans,
http://img481.imageshack.us/img481/2042/merryoldsmobubbleradiatvl6.jpg
MAG it on up...its a large J-pegggg for clarity !
Here is the most critical info that you might need ..its schematic... in case you have any burnt, unidentifiable parts. Hopefuly just the common Ozzie-4 and its associated bufffer cap and / or its vibrator, bad controls, power switch, etc. I have other parts list also, if needed.
And now, just tell us, how did an old fifties model Olds-mo-bubble end up in Belgium..now, if that was in Cuba... I could understand.
Tanks all for the service and the support
Regards,
Frans
Your Tech referencing:
:http://img481.imageshack.us/img481/2042/merryoldsmobubbleradiatvl6.jpg
:MAG it on up...its a large J-pegggg for clarity !
:Here is the most critical info that you might need ..its schematic... in case you have any burnt, unidentifiable parts. Hopefuly just the common Ozzie-4 and its associated bufffer cap and / or its vibrator, bad controls, power switch, etc. I have other parts list also, if needed.
:And now, just tell us, how did an old fifties model Olds-mo-bubble end up in Belgium..now, if that was in Cuba... I could understand.
