Heathkit TC-2 tube tester manual
7/8/2000 5:07:32 PMJim S
Hi All, I'm new to this forum. I was lead here by the fine folke at Ampage. I came across a Heathkit TC-2 tube tester, and was wondering if anyone knew where I could find a manual or schematic. Any input would be appreciated. Thanks Jim S.
7/8/2000 5:42:03 PMWayne
: Hi All, I'm new to this forum. I was lead here by the fine folke at Ampage. I came across a Heathkit TC-2 tube tester, and was wondering if anyone knew where I could find a manual or schematic. Any input would be appreciated. Thanks Jim S.
You can get one for #13.50 at www.manualman.com
7/8/2000 10:28:28 PMJim S
: : Hi All, I'm new to this forum. I was lead here by the fine folke at Ampage. I came across a Heathkit TC-2 tube tester, and was wondering if anyone knew where I could find a manual or schematic. Any input would be appreciated. Thanks Jim S.
: You can get one for #13.50 at www.manualman.com
Thanks for the reply Wanyne. I'll check that site. Jim
12/30/2002 1:22:10 AMWendell
i have a heathkit TC-2 tube tester with manual and schematic.email me and i will make you a copy
12/8/2006 2:16:36 PMJuan
If it is posible I need also a copy of manual TC-2 tube tester. Thank you.
Juan
delacall@eresmas.com
12/8/2006 2:50:30 PMBill VA
:If it is posible I need also a copy of manual TC-2 tube tester. Thank you.
:Juan
:delacall@eresmas.com
All can check out this site too. Save on lots stuff.
http://bama.edebris.com/manuals/heath/tc-2/
12/8/2006 2:56:18 PMRadiodoc
::If it is posible I need also a copy of manual TC-2 tube tester. Thank you.
::Juan
::delacall@eresmas.com
:All can check out this site too. Save on lots stuff.
:http://bama.edebris.com/manuals/heath/tc-2/
Bill VA,
I guess we both had the same idea at about the same time.
12/8/2006 2:54:27 PMRadiodoc
:Juan
Juan,
If perhaps you can not get in contact with those earlier in this post, you may find what you need at:
The information is in .GIF format. Probably can load it into a word processor to print out. Another place for the manual is at:
http://bama.sbc.edu/index.htm
The manuals at BAMA are in DJVU format and you will need either the DJVU browser dropin or the DJVU standalone program to view and print. I believe both are on the site.
12/8/2006 3:34:14 PMDoug Criner
I detest the practice of "selling" Xerox copies of manuals that are already on BAMA for free.
But, more to the point: I have a Heath TC-2. Works fine, but here are some tips:
1. The schematic shows the copper oxide diode installed backwards, at least by today's convention for showing diodes.
2. With modern line voltages, >120V, you may be unable to null the meter. If so, disconnect the black wire going from Terminal 3 of the 100-ohm, 25-W potentiometer to the tap on the transformer primary.
3. The plastic meter dial can take on a static electric charge that cause the meter to do strange things.
:http://bama.sbc.edu/index.htm
:The manuals at BAMA are in DJVU format and you will need either the DJVU browser dropin or the DJVU standalone program to view and print. I believe both are on the site.
:Radiodoc
4/22/2009 3:00:25 PMAnthony
:i have a heathkit TC-2 tube tester with manual and schematic.email me and i will make you a copy
Hi I would like a copy if you still have it
Thanks Tony
