However, is anyone out there confident that they're able to repair the "guts"?? I'm a novice at radio repair and I am a bit intimidated by the "special services" band. For goodness sake, if you can help, email me!!!
Thanks.
: However, is anyone out there confident that they're able to repair the "guts"?? I'm a novice at radio repair and I am a bit intimidated by the "special services" band. For goodness sake, if you can help, email me!!!
: Thanks.
Hello Eric,
I'm in Australia and I'm not familiar with your particular model Philco. I checked Nostalgia Air schematics but can't find any information. However Philco made good radios and I think yours will be fairly straight forward
construction. The special services band could be an extra switched band but I suspect it's the AM broadcast band extended a little higher in frequency to about 1750 kHz or so to pick up the police band just above the broadcast stations. If I can be of any help in getting your set going I'm happy to help all I can though I can't get to work on it (6000 miles is a long service call, definitely NASA range).
Anyway, good luck, hopefully someone in the US will be familliar with your set and can help more. Don.
