Terry in Texas
The 78 tube is rated 6.3 volts at 0.3 amp. The filament is between pins 1 and 6 (the two larger pins).
:I'm restoring a Philco 60 and the 78 tube doesn't seem to be getting any heater voltage. The schematic from NostalgiaAir does not show voltage readings. Does anyone know where I can get a schematic with voltages?
:Thanks,
:Terry in Texas
It dilutes the energy of those who would try to help you. If, after a reasonable period of time, you don't get an answer, then certainly repost elsewhere.
Doug
:Thanks,
:Terry in Texas
And if you were to check you will see this question has already been answered on ARF.
