Zenith 6D2620
3/29/2007 4:47:54 AMfrank goddard
I am trying to find the dial cord diagram for the above radio. Any help please. The puzzle is driving me crazy!
Frank. Doncaster England.
3/29/2007 8:16:54 PMPeter G Balazsy
Frank:
I did a 6d614 that seems to have the same arrangement.
If I remember correctly.
There are two strings.... I think... lol
One small one that goes around the knob shaft and up to the wheel on the tuning condenser itself.
Then ...I think... that bracket that holds the dial numbers has it's own wheel that the pointer is on ... and that wheel takes another dial string that just goes around that wheel itself and over to the other wheel on the tuning condenser.. I believe... lol
Hope that helps a bit.
3/31/2007 5:55:27 AMfrank goddard
:Frank:
:I did a 6d614 that seems to have the same arrangement.
:If I remember correctly.
:There are two strings.... I think... lol
:One small one that goes around the knob shaft and up to the wheel on the tuning condenser itself.
:Then ...I think... that bracket that holds the dial numbers has it's own wheel that the pointer is on ... and that wheel takes another dial string that just goes around that wheel itself and over to the other wheel on the tuning condenser.. I believe... lol
:Hope that helps a bit.
3/31/2007 5:56:47 AMfrank goddard
Peter
You are right on. Good memory. Many thanks. The set now tunes perfectly,
Frank
