I believe RadioDaze has what you want; they have 6 transformers with those ratings, with varying wattages. 5 volt winding is center tapped though. In their latest catalog page 52. Or go on-line.
If the replacement xfmr has a CT that you don't need, just don't hook it up. You can figure the amp requirements for each winding by studying the schematic and consulting tube data.
It may be difficult to find a new xmfr that will exactly match the physical dimensions of the original, so you might have to make some adjustments to the chassis or the mounting. You could check PTOP to see if he has an original.
If only one of the secondary windings is blown, maybe you can install a additional xfmr for just that voltage?
If your xfmr is burned out, be sure that whatever fault may have caused the problem is corrected before enegizing the replacement.
::I need a transformer with these voltages: 5V no CT;
6.3 V with CT; around 600 V with CT, 110 input. Used for Grunow 6C chassis using 1-#80, 2-6D6, 1-6A7, 1-75, 1-80. Vertical style, not basket style. About 4 X 4 X 5 inches. Thanks.
:I believe RadioDaze has what you want; they have 6 transformers with those ratings, with varying wattages. 5 volt winding is center tapped though. In their latest catalog page 52. Or go on-line.
Del,
You may try looking on the Play Things of the Past site for a transformer at:
http://www.oldradioparts.com/
I have bought all my transformers from Gary at www.oldradioparts.com....
You do have to do a little searching in a long but well organized list...being careful to make sure you select the right physical size and mounting type ...then looking for the voltages and current ratings... but you can usualy find the right thing... I always have.
He does have a $20 min order so look for other things you need like tubes and such.
Good luck
