The manual for EICO 625 can be found here:
http://www.nostalgiaair.org/References/Manuals/
Very little to go wrong in this tube tester. Is the power transformer good? Are switch contacts clean? Lose pins in tube sockets?
Tube testers usually have a capacitor in the leakage test circuit. It should be replaced.
:Hi friends.
:I have an EICO 625 model tube tester and I am plaining to restore it.
:It haves some troubles. I have good Electronic experience, I do have the schematics for it and I would like to know is there are some friend who knows the most commom matters about tube testers to help me.
:Thanks a lot from Brazil!
:pcrock
:Hi pcrock
: The manual for EICO 625 can be found here:
:http://www.nostalgiaair.org/References/Manuals/
: Very little to go wrong in this tube tester. Is the power transformer good? Are switch contacts clean? Lose pins in tube sockets?
: Tube testers usually have a capacitor in the leakage test circuit. It should be replaced.
::Hi friends.
::I have an EICO 625 model tube tester and I am plaining to restore it.
::It haves some troubles. I have good Electronic experience, I do have the schematics for it and I would like to know is there are some friend who knows the most commom matters about tube testers to help me.
::Thanks a lot from Brazil!
::pcrock
:HI NORM!!!!!
:VERY VERY THANKS FOR Helping me!!!
:My Eico 625 was buyed on Ebay due here in Brazil, is too much hard to get ones. I buyed it "as is" but as I can see it will be in working condition soon. The most of troubles it has, was already fixed by me. I´ll replace the capacitor as you hint me!
:The transformer looks to be ok, the switches apears to be not so good.
:All the (up/center/down) switches knobs are missing. Do you know a way to get new ones please?
:The roll chart was removed from my unit and in its place was placed an Eico 610 model adapter to it became able to test more tubes types. I do have the tube test data book.
:I need to restore my 625 to test tubes to service Tube Amps Guitars.
:Once more special thanks from Brazil!
:pcrock
::Hi pcrock
:: The manual for EICO 625 can be found here:
::http://www.nostalgiaair.org/References/Manuals/
:: Very little to go wrong in this tube tester. Is the power transformer good? Are switch contacts clean? Lose pins in tube sockets?
:: Tube testers usually have a capacitor in the leakage test circuit. It should be replaced.
:::Hi friends.
:::I have an EICO 625 model tube tester and I am plaining to restore it.
:::It haves some troubles. I have good Electronic experience, I do have the schematics for it and I would like to know is there are some friend who knows the most commom matters about tube testers to help me.
:::Thanks a lot from Brazil!
:::pcrock
