$100 should buy a lot of caps. Where did you buy them?
:I'm planning to re-cap my Eico oscilloscope, and it has three .1uf/1500 volt capacitors.
:From what I gather, putting 2 caps in parallel, won't increase the WVDC, only putting them in series will.
:So basically I would need 4 capacitors which are around 600 OR 650v, pair in both series & parallel (.1 600) to get 1200-1300v at .1 ?
:Would 1200wvdc generally be enough for this type of rig?
:Also, perhaps maybe just two .1's in series for .05 may work in this app? The unit works ok with the old ones so far, just trying to get and idea of what's best. I think the only place that has the HV caps is Allied, and am trying to delay an order from them, as I just spent $100 for a bunch of new caps.
:Just trying to cover all bases, I haven't really calibrated it yet, but the signal from my calibrator looks a bit more sawtooth than square wave (wonder what's up with that), plus the wave is a bit curved across the screen rather that straight (very slightly U shaped).
David S.
:I was just using regular test leads, but I do have a special probe or two that came with it, will have to locate them. That's a good point. Thanks
David S,
Since you have an EICO 460 scope, may I make a suggestion? That suggestion is to not leave the scope on for an extended time. I have a 460 minus the power transformer that I forgot and left on (I had the intensity turned down) over a weekend two times. The first time I came into the shop after the weekend and found the fuse and transformer blown. I ordered a new transformer from EICO and all was well until I did the same thing again. The last time there wasn't anywhere to order the transformer so the scope got put into the storage room to collect dust.
