Pay phone rewiring for home use
3/19/2007 11:48:26 PMDavid
Hello, I know this is not about radios, but I thought you could help. I recently bought an AT&T mid 1980's pay phone and wanted to know how to rewire it to use at home in my basment game room.
David
3/20/2007 2:01:15 AMPeter G Balazsy
I don't know exactly how to by-pass the coin thingie but that part must just be a simple switch which you can force on.
Otherwise just connect the red-wire and the green-wire (that is called "tip" and "ring" for the two end parts of an old-style jack/plug for a switchboard ) to your wall outlet.
Depending on the age and type of the dial mechanism.. ( rotary or tone) you may need to reverse those two wires if the tone buttons don't work.
Otherwise that's all there is to it usually.
3/20/2007 9:21:01 AMLewis L.
:I don't know exactly how to by-pass the coin thingie but that part must just be a simple switch which you can force on.
:Otherwise just connect the red-wire and the green-wire (that is called "tip" and "ring" for the two end parts of an old-style jack/plug for a switchboard ) to your wall outlet.
:Depending on the age and type of the dial mechanism.. ( rotary or tone) you may need to reverse those two wires if the tone buttons don't work.
This site has some telephone schematics, including a coin box, as they call them. I worked for Ma Bell for five years, I might can help you decode the schematic. You might have to do some rewiring. My work was mostly with carrier, I worked mostly on Co-axial and microwave usually with 600 circuits at a time, so my knowlege of two wire circuits is more of less limited.
Lewis L.
www.telephonecollectors.org/library/weco/weco.htm
