I checked the tube voltages (using an isolation transformer) from B- as shown on the chart with the schematic. There were two things I could not explain, the chart indicates there should be 116 volts on
pin 5 of the 35Z5, but this can't be right, there is no pin 5 on a 35Z5. In fact, the lug for pin 5 is used as a tie point for C16 and R11 on my set. This must be a misprint on the voltage chart as I
measure -1.3V at this junction. Additionally, I get 90V where I should have 116V on pins 4 and 8 on the 35Z5. However, all the other tube voltages look good except for the fact they are a little low (76V
where I should have 89V) even with the suggested input of 117V from my Variac. This is probably due to my Fluke 112 as opposed to a VTVM.
The other problem, and probably the one stopping my oscillation is I measure 73V at pin 5 of the 12SA7 where the chart calls for -10V. This is definately a problem. Does anyone have a suggestion? I worked on this radio all weekend and I'm ready for some suggestions from the guys and gals out there. Anyone have any ideas?
David
Best Regards,
Bill Grimm
:I have an Emerson 543 AA5 radio. I have totally recapped this radio and repaced almost all the resistors in this set since they tested more than 20% off spec. The audio section is working since I get a
:loud hum when I touch the grid lead on the 12SQ7. However, it will not pick up any stations. Nothing when the tuning dial is turned, not a blip, nothing, nada!!
:I checked the tube voltages (using an isolation transformer) from B- as shown on the chart with the schematic. There were two things I could not explain, the chart indicates there should be 116 volts on
:pin 5 of the 35Z5, but this can't be right, there is no pin 5 on a 35Z5. In fact, the lug for pin 5 is used as a tie point for C16 and R11 on my set. This must be a misprint on the voltage chart as I
:measure -1.3V at this junction. Additionally, I get 90V where I should have 116V on pins 4 and 8 on the 35Z5. However, all the other tube voltages look good except for the fact they are a little low (76V
:where I should have 89V) even with the suggested input of 117V from my Variac. This is probably due to my Fluke 112 as opposed to a VTVM.
:The other problem, and probably the one stopping my oscillation is I measure 73V at pin 5 of the 12SA7 where the chart calls for -10V. This is definately a problem. Does anyone have a suggestion? I worked on this radio all weekend and I'm ready for some suggestions from the guys and gals out there. Anyone have any ideas?
:David
Richard
Richard,
I'm counting the tube pins clockwise starting at the first pin right of the alignment notch being pin 1. Looking at the tubes upside down as they are installed in the radio.
David
You probably will find that the 35Z5 does have a pin 5 (plate) if you start with the first pin to the left of the index key as pin 1 and count clockwise.
::David, Wondering if you might be counting the tube pins in a CCW direction instead of clockwise from pin 1.
::Richard
:Richard,
:I'm counting the tube pins clockwise starting at the first pin right of the alignment notch being pin 1. Looking at the tubes upside down as they are installed in the radio.
:David
Pin #1 is the first to the left counting clockwise only if the alignment notch is at the 6 o'clock position.
Did I say that right??? lol
I dun it again...assuming one would be looking at the socket with the index at 6 o'clock position. However, let us not forget that some mfgrs left pin 1 out of the socket. I have made the mistake a few times thinking I was looking at pin 1 when it was really pin 2 I was looking at.
:Looking at the bottom of the tube socket pin #1 is to the RIGHT clockwise if the alignment notch is at the 12 o'clock position.
:Pin #1 is the first to the left counting clockwise only if the alignment notch is at the 6 o'clock position.
:Did I say that right??? lol
::Looking at the bottom of the tube socket pin #1 is to the RIGHT clockwise if the alignment notch is at the 12 o'clock position.
::Pin #1 is the first to the left counting clockwise only if the alignment notch is at the 6 o'clock position.
::Did I say that right??? lol
At any rate, I wrote back to thank everyone for their suggestions, I now have the radio fixed.
It turned out to be a broken teeny tiny wire where the oscillator coil connects to the solder lug. I had to use a magnifying glass to repair it, but it is working well. A quick touch up of the alignment, and it's ready for the cabinet.
Thanks again to all that helped!!
David R
