Back to the onset of the "noise"...... could it be categorized as a squeal, that will change in freq a bit as the vol control level is changed ?
1..
Also as I understand your verbiage,if the radio was tuned to the high end of the band to a station..say 1400.. there would be no squeal at any level of the volume controls setting..even at its max?
2...
Whereas,upon tuning down band there would be a point of the onset of that "noise" and its continuing presence on down to the low freq end of the dial. Right?
3...
At the point where the "noise" is the worst, would the volume control have the capability to gradually diminish this "noise" as the volume is incrementally run down, or is there a particular higher volume threshold whereupon the " noise" just disappears ?
4...
Can we assume that in the radio that line item 22, which is an .022ufd AVC line decoupling capacitor, did get replaced ?
5..
On the adjunct condition of the presence of a HUMMMMMM from the speaker ..is it controllable ?.. in the respect, that if you run down the volume, will it have gradually diminished in level and disappeared also, OR is the hum level still present after the volune control is at its min vol position ?
6..
If you will go back and research the above info and then come back and fill in the blanks between the lines, further steps in analysis can then be made.
73 de Edd
