sparton 931
3/3/2007 1:30:11 AMphil
hi all,i'm working on a sparton model 931ac,the schematic i have is so blurry i can read it to verify voltages.
on the scematic are 9 points.here are the voltages i have,all bad resistors replaced,ALL caps replaced except the micas[2].
point1-219
point2-206
point3-2.5ac
piont4-2.5ac
point5-215
point6-231
point7-214
point8-213
point9-213
i'm sure i need some neg grid volts but don't know how much or why not,if you can help or email a clear scan,thanks,phil
philcpphil@yahoo.com
3/3/2007 8:17:51 AMNorm Leal
Hi Phil
I answered on the other forum. You are missing ground on terminal #9. Once grounded others should be ok.
:hi all,i'm working on a sparton model 931ac,the schematic i have is so blurry i can read it to verify voltages.
:on the scematic are 9 points.here are the voltages i have,all bad resistors replaced,ALL caps replaced except the micas[2].
:point1-219
:point2-206
:point3-2.5ac
:piont4-2.5ac
:point5-215
:point6-231
:point7-214
:point8-213
:point9-213
:i'm sure i need some neg grid volts but don't know how much or why not,if you can help or email a clear scan,thanks,phil
:philcpphil@yahoo.com
