radio backing
7/1/2000 10:35:44 AMDave Stoner
I new at restoration & radios in general. My RCA
61-8 is missing the protective back covering. I
have picture of it to make a new one but didn't
know what it was made of. Plastic, cardboard, or
thin wood? Anyone know what the late 40's backs
were made of? Thanks.
7/2/2000 3:09:57 PMGordo
: Hi,
: I new at restoration & radios in general. My RCA
: 61-8 is missing the protective back covering. I
: have picture of it to make a new one but didn't
: know what it was made of. Plastic, cardboard, or
: thin wood? Anyone know what the late 40's backs
: were made of? Thanks.
A new back can be made using "Artist's Board" ... It is a little heavier and thicker than art board and can be found at craft stores ... place the radio face up on the board and trace around it, then measure case thickness and make second inside line that you will cut on .. make holes for screws and you are all done
7/3/2000 8:39:13 AMDave Stoner
Thanks for the tip! I have my work "cut out"
for me. :)
7/3/2000 12:45:56 PMSven Weil
One last word!
Don't forget to cut ventilation holes in the board!!!!
Otherwise there's nowhere for the heat from the tubes to go and
you'll burn up the radio.
7/25/2000 12:53:18 PMAL PUGLIESE
: Thanks for the tip! I have my work "cut out"
: for me. :)
10/24/2004 8:13:11 AMSDP
Would seem this would be a great aftermarket business for someone to start
Shawn
:: Hi,
:: I new at restoration & radios in general. My RCA
:: 61-8 is missing the protective back covering. I
:: have picture of it to make a new one but didn't
:: know what it was made of. Plastic, cardboard, or
:: thin wood? Anyone know what the late 40's backs
:: were made of? Thanks.
:A new back can be made using "Artist's Board" ... It is a little heavier and thicker than art board and can be found at craft stores ... place the radio face up on the board and trace around it, then measure case thickness and make second inside line that you will cut on .. make holes for screws and you are all done
