Need a schematic for Daewoo CMC 1509B monitor.
6/30/2000 8:35:43 PMAnderson Cox
I need a schematic for Daewoo CMC 1509B monitor.
A.Cox
7/2/2000 11:04:48 PMJohn McPherson
If there is a "GS" on the back, it was manufactured by "Goldstar", and you can get relevent info here:
http://www.anatekcorp.com/sfmsap.htm
If it is not, and not a variant in the list at the above url, check here:
http://www.samswebsite.com/
If they are not able to supply the information soon enough, your most common sources of failure are the Horizontal Output Transistor (HOT), which will be the big one on the heatsink, usually a TO-3. These often breakdown, and are fairly easy to test with any meter, as they either open completely, or they short out (lose diode effect of the transistor).
The other failure is the capacitors in the switching power supplies, the moderate value caps with working voltages from 180 to 350 WVDC (usually 3- 40 Mfd). Replacements should be kept to the same capacity, but higher working voltage.
: I need a schematic for Daewoo CMC 1509B monitor.
: A.Cox
11/5/2001 4:39:47 AMmisa
: Hi,
: If there is a "GS" on the back, it was manufactured by "Goldstar", and you can get relevent info here:
: http://www.anatekcorp.com/sfmsap.htm
: If it is not, and not a variant in the list at the above url, check here:
: http://www.samswebsite.com/
: If they are not able to supply the information soon enough, your most common sources of failure are the Horizontal Output Transistor (HOT), which will be the big one on the heatsink, usually a TO-3. These often breakdown, and are fairly easy to test with any meter, as they either open completely, or they short out (lose diode effect of the transistor).
: The other failure is the capacitors in the switching power supplies, the moderate value caps with working voltages from 180 to 350 WVDC (usually 3- 40 Mfd). Replacements should be kept to the same capacity, but higher working voltage.
: : I need a schematic for Daewoo CMC 1509B monitor.
: : A.Cox
5/22/2001 9:28:16 AMEvgen
: A.Cox
