http://www.nostalgiaair.org/PagesByModel/466/M0014466.pdf
http://www.nostalgiaair.org/PagesByModel/467/M0014467.pdf
Is your utility voltage there 120V or 220V? I'm wondering how the heater string adds up to the line voltage? Is there a dropping resistor in there somewhere?
The original rectifier (25Z5) is a full-wave rectifier. It was replaced with two silicon diodes? That's fine, but it eliminates 25V from the heater string.
:The tube line-up is: 6K7, 6K8, 6K7GT, 6Q7GT, 25L6, 6E5 and a 25Z5 with only the filament conected to the circuit (AM with 3 bands, Broadcast and two Short Wave). The radio is made in USA, maybe for export only (I´m from Argentina). I was looking for the schematics because some components were replaced with modern ones, like caps and the silicon rectifier.
:Many thanks for your help!
"The original rectifier (25Z5) is a full-wave rectifier. It was replaced with two silicon diodes?"
I hope not since the sil diodes are instant power and the
wait for the power output and its companions to warm up are going to leave the PS unloaded with quite a peak voltage jolt going to the PS filters initially. With the
orig rect being tube the power onset would be gradual, just like its companion tube warm up periods.
IF still in Argentina trying to use that unit, and not presently being stateside with the unit.
I certainly think that he has 220VAC power, to be acquired with the most common round plug pins being for its AC power connector.
If a conversion of a US 117V AC/DC unit was done, to be used with that 220VAC supply, the simplest manner possibly might have been the utilization of a hefty AC line series diode, polarity oriented so that only the + nodes are passed. That, possibly along with a series current limiting resistor.
Sooo that might be what is being referred to.
Hi guys!!!! I was working in the radio and found that there was no sense in the use of the silicon diode, because the 25Z5 tested 100%!!!! The G-184 is quite similar to my radio and I realized that the use of the 25Z5 is for half-wave rectification but with the two diodes in parallel so I conected that way and worked fine, there a resistor for the voltage drop installed in the speaker chassis. The voltage of the filaments are apropiated for each ones of the tubes so I think that resistor is a factory adpatation for the 220AC in my country or maybe some technician do it...
There is only one thing that I was wondering, in place of the 6A8 in the radio were a 6K8 (¿?)
Many thanks for your great help!!!!
Ref:
http://www.nj7p.org/Tube4.php?tube=6K8
http://www.nj7p.org/Tube4.php?tube=6A8
