chairside -Silvertone radio (dated about mid 30's
2/21/2007 11:13:48 AMbud
Need help identifying Selvertone radio. from the tube layout it is mid 30's. recently purchased Silverton radio catalog 1930-1942. but not listed there. looking for suggestions and/or reference materiel. tnks
2/21/2007 11:15:09 AMbud
:Need help identifying Selvertone radio. from the tube layout it is mid 30's. recently purchased Silverton radio catalog 1930-1942. but not listed there. looking for suggestions and/or reference materiel. tnks
I have picturs to send if it will help.
2/21/2007 12:22:41 PMCarl
Bud,
Have you looked at the Silvertones pictured in the Radio Attic archives?
http://radioatticarchives.com/archive_s3.htm
2/21/2007 4:46:06 PMbud
::Need help identifying Selvertone radio. from the tube layout it is mid 30's. recently purchased Silverton radio catalog 1930-1942. but not listed there. looking for suggestions and/or reference materiel. tnks
:Bud,
:Have you looked at the Silvertones pictured in the Radio Attic archives?
: http://radioatticarchives.com/archive_s3.htm
I think so, will ccheck to be sure
2/21/2007 4:51:12 PMbud
:::Need help identifying Selvertone radio. from the tube layout it is mid 30's. recently purchased Silverton radio catalog 1930-1942. but not listed there. looking for suggestions and/or reference materiel. tnks
::Bud,
::Have you looked at the Silvertones pictured in the Radio Attic archives?
:: http://radioatticarchives.com/archive_s3.htm
carl. thanks for the tip, interesting page. my radio not shown
:I think so, will ccheck to be sure
2/21/2007 10:18:17 PMCarl
Bud,
How about posting the tube line up.
May be able to identify it that way.
Carl
2/22/2007 9:40:41 PMbud
:Bud,
:How about posting the tube line up.
:May be able to identify it that way.
:Carl
Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
2/23/2007 10:52:51 AMCarl
::Bud,
::How about posting the tube line up.
::May be able to identify it that way.
::Carl
:Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
Bud,
I went through the Silvertone radios in the Mallory Encyclopedia and could not find a tube line up that matched your radio.
Carl
2/23/2007 11:14:48 PMBud
:::Bud,
:::How about posting the tube line up.
:::May be able to identify it that way.
:::Carl
::Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
:Bud,
:I went through the Silvertone radios in the Mallory Encyclopedia and could not find a tube line up that matched your radio.
:Carl
Carl please check one more time subtitute a type 41 for the 6V6. Thanks, Bud
2/24/2007 12:52:18 AMCarl C.
::::Bud,
::::How about posting the tube line up.
::::May be able to identify it that way.
::::Carl
:::Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
::Bud,
::I went through the Silvertone radios in the Mallory Encyclopedia and could not find a tube line up that matched your radio.
::Carl
:Carl please check one more time subtitute a type 41 for the 6V6. Thanks, Bud
Bud: Check Colonial Radio Models 600 and 600AC in Rescources this site.
Carl C.
2/24/2007 9:18:30 AMBud
:::::Bud,
:::::How about posting the tube line up.
:::::May be able to identify it that way.
:::::Carl
::::Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
:::Bud,
:::I went through the Silvertone radios in the Mallory Encyclopedia and could not find a tube line up that matched your radio.
:::Carl
::Carl please check one more time subtitute a type 41 for the 6V6. Thanks, Bud
:Bud: Check Colonial Radio Models 600 and 600AC in Rescources this site.
: Carl C.
Carl - Thank you for you help. Bud
2/24/2007 8:02:11 PMCarl T
::::::Bud,
::::::How about posting the tube line up.
::::::May be able to identify it that way.
::::::Carl
:::::Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
::::Bud,
::::I went through the Silvertone radios in the Mallory Encyclopedia and could not find a tube line up that matched your radio.
::::Carl
:::Carl please check one more time subtitute a type 41 for the 6V6. Thanks, Bud
::Bud: Check Colonial Radio Models 600 and 600AC in Rescources this site.
:: Carl C.
:Carl - Thank you for you help. Bud
Bud,
The Colonial 650 is another possibility that uses a 41 instead of a 6V6.
http://www.nostalgiaair.org/PagesByModel/856/M0002856.pdf
Carl
2/26/2007 2:47:52 PMBud
:::::::Bud,
:::::::How about posting the tube line up.
:::::::May be able to identify it that way.
:::::::Carl
::::::Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
:::::Bud,
:::::I went through the Silvertone radios in the Mallory Encyclopedia and could not find a tube line up that matched your radio.
:::::Carl
::::Carl please check one more time subtitute a type 41 for the 6V6. Thanks, Bud
:::Bud: Check Colonial Radio Models 600 and 600AC in Rescources this site.
::: Carl C.
::Carl - Thank you for you help. Bud
:Bud,
:The Colonial 650 is another possibility that uses a 41 instead of a 6V6.
:http://www.nostalgiaair.org/PagesByModel/856/M0002856.pdf
:Carl
the 600 and 600AC are 6 tube sets my is a five tube set. Bud
5/13/2008 12:52:33 AMMichael Adkison
::::::::Bud,
::::::::How about posting the tube line up.
::::::::May be able to identify it that way.
::::::::Carl
:::::::Tubes: 6A7, 78, 75, 6V6, Type 80. Dial Says Silvertone, 3 Band. metal Tag on back of chassis has the number 833, mfg. in Los Angles, Serial # 49388. Wood cabinet is: 20 1/2 high, 13 1/2 wide andf 24 3/4 long. Ends are rounded making it almost oval shape.
::::::Bud,
::::::I went through the Silvertone radios in the Mallory Encyclopedia and could not find a tube line up that matched your radio.
::::::Carl
:::::Carl please check one more time subtitute a type 41 for the 6V6. Thanks, Bud
::::Bud: Check Colonial Radio Models 600 and 600AC in Rescources this site.
:::: Carl C.
:::Carl - Thank you for you help. Bud
::Bud,
::The Colonial 650 is another possibility that uses a 41 instead of a 6V6.
::http://www.nostalgiaair.org/PagesByModel/856/M0002856.pdf
::Carl
:the 600 and 600AC are 6 tube sets my is a five tube set. Bud
Solved the mystery!! This radio was made for Silvertone by Mission Bell. Model 3859. Modified for use with push button tuning. Schematic can be found in Rider's Vol. 10; Mission Bell 10-10. IF 465 KC.
Designed in 1937; probably a 1938 model.
I just bought one, Serial #51591
