Philco 49-900
2/20/2007 2:40:47 PMfrank goddard
I am repairing a Philco 49-900. The radio has fitted to it 14F7 tube instead of a 14AF7. I get a 'cut off' from time to time Just for a mini second or so. I can find no faults with the radio but suspect this tube may be the culprit. Should I change it for the correct one or will this replacement tube work well enough and I have a fault as yet unfound.
Frank Goddard. Doncaster. England.
2/20/2007 4:11:44 PMRadiodoc
:I am repairing a Philco 49-900. The radio has fitted to it 14F7 tube instead of a 14AF7. I get a 'cut off' from time to time Just for a mini second or so. I can find no faults with the radio but suspect this tube may be the culprit. Should I change it for the correct one or will this replacement tube work well enough and I have a fault as yet unfound.
:Frank Goddard. Doncaster. England.
Frank,
All my substitution books do not show a direct sub for the 14F7 tube. The 14F7 is a high-mu twin triode whereas the 14AF7 is a medium-mu twin triode. Both have the same basing.
2/20/2007 4:19:27 PMRa diodoc
::I am repairing a Philco 49-900. The radio has fitted to it 14F7 tube instead of a 14AF7. I get a 'cut off' from time to time Just for a mini second or so. I can find no faults with the radio but suspect this tube may be the culprit. Should I change it for the correct one or will this replacement tube work well enough and I have a fault as yet unfound.
::Frank Goddard. Doncaster. England.
:Frank,
:All my substitution books do not show a direct sub for the 14F7 tube. The 14F7 is a high-mu twin triode whereas the 14AF7 is a medium-mu twin triode. Both have the same basing.
:Radiodoc
Frank,
Hit enter before I was finished. An XXD may be substituted for the 14AF7 tube.
2/22/2007 8:14:43 AMfrank goddard
Thanks for the help so far. Can't find a substitute myself either.
Frank
::All my substitution books do not show a direct sub for the 14F7 tube. The 14F7 is a high-mu twin triode whereas the 14AF7 is a medium-mu twin triode. Both have the same basing.
::Radiodoc
:Frank,
:Hit enter before I was finished. An XXD may be substituted for the 14AF7 tube.
:Radiodoc
