There is a 48-03-040934-03 listed as ECG130. Might be the same or a slight revision?
ECG130 is a NPN silicon power transistor. Collector to Emitter voltage = 60. Max current 15 amps. Max dissipation = 115 watts.
ECG130 crosses to 2N3055. I would try 2N3055 which is a common transistor.
:I am in need of some assistance (info) that I am hoping someone here might have.
: I’m looking for six RCA transistors (that I am unable to cross-reference), the part number on these is: 48-03-040934-02
:They appear to be the TO-3 type and go in an Altec 1594A amplifier.
:Is this enough info, and can anyone help?
:Hi Bob
: There is a 48-03-040934-03 listed as ECG130. Might be the same or a slight revision?
: ECG130 is a NPN silicon power transistor. Collector to Emitter voltage = 60. Max current 15 amps. Max dissipation = 115 watts.
: ECG130 crosses to 2N3055. I would try 2N3055 which is a common transistor.
::I am in need of some assistance (info) that I am hoping someone here might have.
:: I’m looking for six RCA transistors (that I am unable to cross-reference), the part number on these is: 48-03-040934-02
::They appear to be the TO-3 type and go in an Altec 1594A amplifier.
::Is this enough info, and can anyone help?
