HOWEVER! Here's the radical new idea! (Perhaps it's old, but I've never seen it before.) Let's say you're using a 12SQ7. Connect the plate directly to B+ instead of to a 1 meg resistor. Connect the 1 meg resistor to B- and the cathode instead. Tap the audio at the cathode. Now, instead of connecting the grid resistor to B-, connect it to the cathode as well. Normally, in radios, when the cathode is grounded, the grid resistor is grounded as well. Well, if you put a resistor between the cathode and B-, you must put the grid at the same potential as the cathode for this particular tube.
Now, that is kind of exciting, but nothing fantastic. So you're taking the audio at the cathode instead of the plate. Big deal. Now do it to a pentode of any kind. Let's take a 50L6. It requires a 150 ohm cathode bias resistor. Connect this resistor to the cathode. To the other side connect one leg of the primary of the output transformer. Connect the other leg to B-. Where the transformer and the resistor join, connect the grid bias resistor. Connect both the screen grid and the plate to B+. Here's what's so wonderful about this technique: At the plate, some electrons get collected at the screen grid. The plate doesn't realize the full electron flow (this is inefficient amplification). Also, if the tube isn't a beam grid tube, the electrons bounce around. This ruins fidelity at the plate. However, at the cathode, ALL currents that flow through the tube must first flow in here. With the output transformer (or load resistor) at the cathode, full power and fidelity can be realized. There will be no wasted wattage, because the current for both the screen grid and the plate will flow through the output transformer if it is connected at the cathode as previously described.
You would think that with the cathode changing all over the place, the grid would get confused, but its bias changes instantaneously with the cathode, and is always at the correct bias.
I haven't tried this idea with an output tube yet, but I have tried it with a pre-amplifier pentode and triode, and both work quite well with complete gain.
This isn't the idea that I wanted to patent, though I guess I could if noone else has used it yet. I think that someone somewhere has, though.
This is why I love posting here! These are great ideas and it gets your mind working!
Cathode follower/common cathode amplifier.
http://www.tubecad.com/2005/August/blog0053.htm
Z-
Please provide a schematic. It's easier to understand with a schematic than with words.
Z-
Isn't this a standard cathode follower circuit? In this type of circuit there isn't any voltage gain. Instead you will have current gain. In addition there is no signal inversion like the more common plate output stage.
:Here's a radical new one that I don't think I've seen yet. They say that you can't take the output from the cathode if you want gain. Here's why this is normally not possible: If you put the load resistor at the cathode, and tap the audio (or whatever) from the cathode, the changing load will also change the grid bias, if the grid is connected to B- in the conventional manner. If the tube starts conducting more, the cathode-grid difference will increase, and the grid will swing more negative (with respect to the cathode). This will cancel out all gain.
:HOWEVER! Here's the radical new idea! (Perhaps it's old, but I've never seen it before.) Let's say you're using a 12SQ7. Connect the plate directly to B+ instead of to a 1 meg resistor. Connect the 1 meg resistor to B- and the cathode instead. Tap the audio at the cathode. Now, instead of connecting the grid resistor to B-, connect it to the cathode as well. Normally, in radios, when the cathode is grounded, the grid resistor is grounded as well. Well, if you put a resistor between the cathode and B-, you must put the grid at the same potential as the cathode for this particular tube.
:Now, that is kind of exciting, but nothing fantastic. So you're taking the audio at the cathode instead of the plate. Big deal. Now do it to a pentode of any kind. Let's take a 50L6. It requires a 150 ohm cathode bias resistor. Connect this resistor to the cathode. To the other side connect one leg of the primary of the output transformer. Connect the other leg to B-. Where the transformer and the resistor join, connect the grid bias resistor. Connect both the screen grid and the plate to B+. Here's what's so wonderful about this technique: At the plate, some electrons get collected at the screen grid. The plate doesn't realize the full electron flow (this is inefficient amplification). Also, if the tube isn't a beam grid tube, the electrons bounce around. This ruins fidelity at the plate. However, at the cathode, ALL currents that flow through the tube must first flow in here. With the output transformer (or load resistor) at the cathode, full power and fidelity can be realized. There will be no wasted wattage, because the current for both the screen grid and the plate will flow through the output transformer if it is connected at the cathode as previously described.
:You would think that with the cathode changing all over the place, the grid would get confused, but its bias changes instantaneously with the cathode, and is always at the correct bias.
:I haven't tried this idea with an output tube yet, but I have tried it with a pre-amplifier pentode and triode, and both work quite well with complete gain.
:This isn't the idea that I wanted to patent, though I guess I could if noone else has used it yet. I think that someone somewhere has, though.
:T.
Thomas, I agree with Norm in that this is a cathode follower also known as "common plate" amplifer in which the voltage gain cannot exceed mu over mu + 1. However, the power gain can be substantial AND you can artificially achieve a voltage gain by using a transformer in the cathode circuit as a load, then you can get any kind of phase reversal you please by simply changing your transformer arrangement. This would also allow you to cascade stages should you so desire.
http.//www.tubecad.com/2005/June/blog0048.htm
Have a great day
MRO
But just ye remember.... a cathode follower is a cathode follower....IS A CATHODE FOLLOWER.
The tube amps builders" reinventing" it, resplendently
complete with its "audiofool" "transparency" vague descriptives.
http://www.valvediy.com/pnppg2.html
BIGGGGGG BUCKS fruitless patenting:
http://www.patentstorm.us/patents/5859565.html
http://www.metroflog.com/bigbadpiratetom
Lewis L.
:Hi Thomas
: Isn't this a standard cathode follower circuit? In this type of circuit there isn't any voltage gain. Instead you will have current gain. In addition there is no signal inversion like the more common plate output stage.
::Here's a radical new one that I don't think I've seen yet. They say that you can't take the output from the cathode if you want gain. Here's why this is normally not possible: If you put the load resistor at the cathode, and tap the audio (or whatever) from the cathode, the changing load will also change the grid bias, if the grid is connected to B- in the conventional manner. If the tube starts conducting more, the cathode-grid difference will increase, and the grid will swing more negative (with respect to the cathode). This will cancel out all gain.
::HOWEVER! Here's the radical new idea! (Perhaps it's old, but I've never seen it before.) Let's say you're using a 12SQ7. Connect the plate directly to B+ instead of to a 1 meg resistor. Connect the 1 meg resistor to B- and the cathode instead. Tap the audio at the cathode. Now, instead of connecting the grid resistor to B-, connect it to the cathode as well. Normally, in radios, when the cathode is grounded, the grid resistor is grounded as well. Well, if you put a resistor between the cathode and B-, you must put the grid at the same potential as the cathode for this particular tube.
::Now, that is kind of exciting, but nothing fantastic. So you're taking the audio at the cathode instead of the plate. Big deal. Now do it to a pentode of any kind. Let's take a 50L6. It requires a 150 ohm cathode bias resistor. Connect this resistor to the cathode. To the other side connect one leg of the primary of the output transformer. Connect the other leg to B-. Where the transformer and the resistor join, connect the grid bias resistor. Connect both the screen grid and the plate to B+. Here's what's so wonderful about this technique: At the plate, some electrons get collected at the screen grid. The plate doesn't realize the full electron flow (this is inefficient amplification). Also, if the tube isn't a beam grid tube, the electrons bounce around. This ruins fidelity at the plate. However, at the cathode, ALL currents that flow through the tube must first flow in here. With the output transformer (or load resistor) at the cathode, full power and fidelity can be realized. There will be no wasted wattage, because the current for both the screen grid and the plate will flow through the output transformer if it is connected at the cathode as previously described.
::You would think that with the cathode changing all over the place, the grid would get confused, but its bias changes instantaneously with the cathode, and is always at the correct bias.
::I haven't tried this idea with an output tube yet, but I have tried it with a pre-amplifier pentode and triode, and both work quite well with complete gain.
::This isn't the idea that I wanted to patent, though I guess I could if noone else has used it yet. I think that someone somewhere has, though.
::T.
Lewis L.
:Hi Thomas
::T.
Aside observations:
With the first amp stage you are configuring as a cathode follower ...e.g. current amplifier stage , however, the abnormally high cathode resistor value sugggests of convential voltage amplifier logic.
The final output circuit stages effective power level is not aided by that parasitic 150 ohm resistor . Since the power is then proportionatively divided between it and the O/P xformer.
Screen current consumption is typically minumal, in its trade off benefits of its static accelerating potential of and amassing the electron beam stream .
Hook up your initial circuit and use an audio source to confirm that circuits definitive potential max output level.
Now, agreed on the bottleneck 150 ohm series resistor, but why not rethink your manner of the acquisition of that biasing voltage.
With your present selection of 470 k for that grid resistor, the max required currrent draw that might ever be permitted through that path would be ~ 450 ua worst case.
Try eliminating the 150 ohm and connecting the O/P direct to the cathode and ...considering that you want to keep within the same low Z that was initially presented by that leg of the circuitry... install a 150 ohm (or upwards in value) pot across the O/P xfmr and take your then acquired, adjustable voltage off its CT to feed to the grid resistors low end.
There possibly might be some unknown transitional threshold within its adjustment range that
might initiate a shift from mild negative feed back towards positive feedback, so be prepared
for additive mild capacitive filtering of that derived bias voltage as referenced to either / both cathode and / or ground.
Re-evaluation for power outtut and performance ?
You'd need 150 Ohms DC for the grid bias, and that would be how many Ohms reactance to the audio?
Lewis L.
