Tech reference:
http://img252.imageshack.us/img252/8629/philcowiringxy7.jpg
I got it back up and running. On my next project, ALL connections will be marked! Hard lesson learned.
:Shame...shame...shame.... as Gomer Pyle used to say...
:Heres probably the best that I can offer without an actual eyeballing of the unit. Pending that you can see the fresh solder of where the wires were disconnected...better to just snip them with abou a n 1/8 in of wire snippet left as a marker as well as its color coding. If I interpret your info, you have the two wires from the variable tuning condenser
:that were connecteed to the tuning unit. I have an accompanying markup with the Tuning caps sections 21A and B
:enclosed in green and fuscia channels to the point where they connect on the manual/automatic tuning switch clusters
:connection points.
:As for the 7J7 wiring up to that cluster, two routes are possible since you did not give that tubes pin number.
:If off the plate , trace down the blue zig zag route and you will see that it terminates into a silver mica cap, now I think that this is probably not your wire of concern.
:More likely it is the the zig- zaged grid wires route (done in red) that terminates to two contacts on that switch cluster.
:That accounts for two wires coming from the tuning capacitor and one from the osc section of the mixer...7J7.
:Pull out yer ohmmeter and CHECK IT OUT ...as they say...
:Tech reference:
:http://img252.imageshack.us/img252/8629/philcowiringxy7.jpg
