Cap Question
2/17/2007 4:51:42 PMJeff S.
I'm recapping a Zenith 9S232 Shutterdial console. Cap C-4 (Zenith part #22-487C) has a wire mesh coming out of both ends instead of the usual solid wire. There are two of them in the set. I never saw one of these before, and I don't know the reason for the wire mesh. Is is safe to replace these with a standard .047/630v poly cap (no wire mesh, just wire)?
Thanks///Jeff S.
2/17/2007 5:58:48 PMrghines1
New caps with solid wire leads is Ok. Hate to speculate on the mesh feature.
Richard
2/17/2007 7:06:47 PMNorm Leal
Hi
As Richard suggested use standard modern caps. They must have thought using this stranded wire, like in a shield, was lower loss?
:New caps with solid wire leads is Ok. Hate to speculate on the mesh feature.
:Richard
2/19/2007 11:10:33 AMJeff S.
Who knows why they made them this way. Maybe because they are both grounded to the chassis and it was easier to solder a braid than a solid wire????
Thanks for the help!
Jeff S.
:Hi
: As Richard suggested use standard modern caps. They must have thought using this stranded wire, like in a shield, was lower loss?
::New caps with solid wire leads is Ok. Hate to speculate on the mesh feature.
::Richard
