You might try a large library near you. Many of the larger libraries stock the entire Sams collection in their Technical Reference Depts.
:The Sams Index lists a model 808 under the "Chrysler" heading.
:Set 107 - folder 6.
:Unfortunately I do not have that Photofact but could probably borrow a copy sometime over the next several days......(if you are in no hurry).
: You might try a large library near you. Many of the larger libraries stock the entire Sams collection in their Technical Reference Depts.
Ricky: I believe that radio was made by Philco for Chrysler. It should be a 2 piece arrangement with the tuner seperate from the power supply/amp chassis if it is the one I am thinking of. The last gentleman steered you right on the schematic. Good luck, Tom.
::I have a radio that is stamped mopar model 808. fits a 1950 desoto car. Anyone have any idea what schematic this one would use? Might it be made by someone else. Appreciate any help!!
:Ricky: I believe that radio was made by Philco for Chrysler. It should be a 2 piece arrangement with the tuner seperate from the power supply/amp chassis if it is the one I am thinking of. The last gentleman steered you right on the schematic. Good luck, Tom.
Hi Ricky,
Mopar 808 was made by Motorola. Sams 107-6 is correct, and it's also found in Sams auto radio series AR-2. For a similar schematic, look on the resources page here for Motorola 814--uses 6AQ5's instead of 6V6's, but otherwise very close.
Beitmans manuals may have it, I don't know the online source for them.
If you need a copy of the service instructions, send me an email with your mailing address.
Meade
:Hi Ricky,
:Mopar 808 was made by Motorola. Sams 107-6 is correct, and it's also found in Sams auto radio series AR-2. For a similar schematic, look on the resources page here for Motorola 814--uses 6AQ5's instead of 6V6's, but otherwise very close.
:Beitmans manuals may have it, I don't know the online source for them.
:If you need a copy of the service instructions, send me an email with your mailing address.
:Meade
