Audio transformers
2/14/2007 8:42:04 AMPaul
What are the correct replacements for 1:3 and 1:5 ratio audio transformers from AES or Radiodaze?. I have a couple early homebrew sets that have open windings and cant figure out which ones I need. Thanks a million for any help.
Paul.
2/14/2007 10:19:02 AMDoug Criner
Paul, we're talking about audio interstage xfmrs, correct? Used in '20s TRF sets.
The RadioDaze part no. is HX124A, $13.26. HX124C is just the coil that you might be able to fit onto your existing iron if the core is 1/2" square. AES has comparable items.
These are 1:3 xfmrs. Should work fine for either of your needs.
:What are the correct replacements for 1:3 and 1:5 ratio audio transformers from AES or Radiodaze?. I have a couple early homebrew sets that have open windings and cant figure out which ones I need. Thanks a million for any help.
:Paul.
2/14/2007 12:02:16 PMPaul
:Paul, we're talking about audio interstage xfmrs, correct? Used in '20s TRF sets.
:The RadioDaze part no. is HX124A, $13.26. HX124C is just the coil that you might be able to fit onto your existing iron if the core is 1/2" square. AES has comparable items.
:These are 1:3 xfmrs. Should work fine for either of your needs.
Doug,
Yes thet are interstage tranformers in battery sets from the 20's. Many thanks for the info. I hope to be able to fit them in the original cases. They look very cool.
Many thanks,
Paul.
::What are the correct replacements for 1:3 and 1:5 ratio audio transformers from AES or Radiodaze?. I have a couple early homebrew sets that have open windings and cant figure out which ones I need. Thanks a million for any help.
::Paul.
