You probobly have a 12SQ7 somewhere close to the 50L6.
This is the guy that does the amplifying, while the 50L6 does the heavy work. This being a series filament radio, you will need to leave the two RF tubes (12SA7 & 12SK7? We're going way back in memeory here!) or add a resistor to drop 24 Volts. I don't know the output of a guitar pickup compared to a crystal pickup, but in my teenage years I converted radios to use the new RCA 45 rpm changers that come on the market by putting a RCA jack and a spdt switch at the hot end of the volume control on many a young lady's radio. Too bad nerds were not yet cool, I only got a couiple of bucks, and she swooned over Elvis.
Lewis L.
::Ok I have a zenith clunker chassis with no id on it whatsoever. It has a 50l6 output with 12 series detectors ect.( all american 5) looks like a fourties model. ("war tubes", no clips ect.)
::This thing has no case and radio section is dead, so I just made a guitar amp out of it.
::Hate to throw it out!
:: Now since I don not have a schematic and it has a rca input jack on it, does the input feed the 50L6 directly or is it going through one of the 12 series tubes? I am asking this as I found a hookup point that sounds pleasant as a clean channel better than just using the rca jack, but would
::like to tinker a bit to get a second bluesier tone.
::Is there an actual pre amp? or is all done with the output tube?
:You probobly have a 12SQ7 somewhere close to the 50L6.
:This is the guy that does the amplifying, while the 50L6 does the heavy work. This being a series filament radio, you will need to leave the two RF tubes (12SA7 & 12SK7? We're going way back in memeory here!) or add a resistor to drop 24 Volts. I don't know the output of a guitar pickup compared to a crystal pickup, but in my teenage years I converted radios to use the new RCA 45 rpm changers that come on the market by putting a RCA jack and a spdt switch at the hot end of the volume control on many a young lady's radio. Too bad nerds were not yet cool, I only got a couiple of bucks, and she swooned over Elvis.
:Lewis L.
Rich
:thats why I played guitar lol!
:I belive I do have the 'sq7 great now i'll fiddle around in that area!
:::Ok I have a zenith clunker chassis with no id on it whatsoever. It has a 50l6 output with 12 series detectors ect.( all american 5) looks like a fourties model. ("war tubes", no clips ect.)
:::This thing has no case and radio section is dead, so I just made a guitar amp out of it.
:::Hate to throw it out!
::: Now since I don not have a schematic and it has a rca input jack on it, does the input feed the 50L6 directly or is it going through one of the 12 series tubes? I am asking this as I found a hookup point that sounds pleasant as a clean channel better than just using the rca jack, but would
:::like to tinker a bit to get a second bluesier tone.
:::Is there an actual pre amp? or is all done with the output tube?
::You probobly have a 12SQ7 somewhere close to the 50L6.
::This is the guy that does the amplifying, while the 50L6 does the heavy work. This being a series filament radio, you will need to leave the two RF tubes (12SA7 & 12SK7? We're going way back in memeory here!) or add a resistor to drop 24 Volts. I don't know the output of a guitar pickup compared to a crystal pickup, but in my teenage years I converted radios to use the new RCA 45 rpm changers that come on the market by putting a RCA jack and a spdt switch at the hot end of the volume control on many a young lady's radio. Too bad nerds were not yet cool, I only got a couiple of bucks, and she swooned over Elvis.
::Lewis L.
Now, you can leave the pre-amp wide open and just control the volume after it. If you play loud, you can distort and still keep the speaker low. Another thing you can do is instead put the volume control at the beginning of the chain right at the RCA jack. However, if you want versatility, you can put in two volume controls. Leave the current one wired as-is. Then wire in another one (preferrably 1 meg for good gain) at the RCA jack. Turn the current one all the way up and use the one at the RCA jack if you want control without distortion. Turn the one at the RCA jack all the way up and the currently existing one down to where you want it if you want low volume and lots of distortion.
You can add even more pre-amplification if you want by putting changing the 12SA7 to a 12SK7, and then wire it as before. You can also wire the 12SA7 as a pre-amplifier. This tube is versatile, and can even be wired as both a pre-amplifier and a vibrato. My vibrato circuit isn't that good. It works alright at higher frequencies, but if slowed down really slow, it creates a popping sound. It is alright at normal frequencies, though--one's you'd use. I'm sure you can find better circuits in Fender schematics.
I recommend converting the radio so that it has pre-amplification. However, if you manage to get good volume out of the current set-up, you can disconnect the RF B supply all together, and get more power out of the output. Actually, even if you do wire in a pre-amplifier, load resistors are such that it will draw much less than the RF circuitry, so you'll still get a bit more power even with the tubes still drawing current.
:Yeah. Be careful with that amp. Once I built a 5 tube AC/DC guitar amplifier for my brother. It worked quite well and even had vibrato. You can actually make use of the extra tubes in that radio for more power. Wire the 12SK7 as a pre-amplifier (which is what you really want with a magnetic pick-up.....the 12SQ7 isn't enough). Use 2700K and 30 MFD in parallel for the cathode and supressor (grid 3). Use 1 to 3 meg to B+ for the screen (B+ after the filter resistor). Connect a .1 MFD from the screen to B-. Use between 500K and 1 meg from the plate to B+ (again, after the filter resistor). Increasing the value increases gain and bass. Decrease for less bass. Connect a condenser between .01 and .002 MFD between the plate and the high end of the volume control. Larger value passes more bass. Reduce value and increase plate resistance for less bass and more gain. Connect a 1 meg from the 12SK7 grid 1 to B-. Connect a condenser between .002 and .01 MFD(possibly more) between grid 1 and the RCA jack center terminal (omit original connection to volume control).
:Now, you can leave the pre-amp wide open and just control the volume after it. If you play loud, you can distort and still keep the speaker low. Another thing you can do is instead put the volume control at the beginning of the chain right at the RCA jack. However, if you want versatility, you can put in two volume controls. Leave the current one wired as-is. Then wire in another one (preferrably 1 meg for good gain) at the RCA jack. Turn the current one all the way up and use the one at the RCA jack if you want control without distortion. Turn the one at the RCA jack all the way up and the currently existing one down to where you want it if you want low volume and lots of distortion.
:You can add even more pre-amplification if you want by putting changing the 12SA7 to a 12SK7, and then wire it as before. You can also wire the 12SA7 as a pre-amplifier. This tube is versatile, and can even be wired as both a pre-amplifier and a vibrato. My vibrato circuit isn't that good. It works alright at higher frequencies, but if slowed down really slow, it creates a popping sound. It is alright at normal frequencies, though--one's you'd use. I'm sure you can find better circuits in Fender schematics.
:I recommend converting the radio so that it has pre-amplification. However, if you manage to get good volume out of the current set-up, you can disconnect the RF B supply all together, and get more power out of the output. Actually, even if you do wire in a pre-amplifier, load resistors are such that it will draw much less than the RF circuitry, so you'll still get a bit more power even with the tubes still drawing current.
:T.
Tom-
Am I cutting out the 12sq7 all-together and running from input to 12sk7 then making your connections to output?
Do you know which stock diagram I would use so I can keep track of all my steps? I have no idea which model it is, but it sounds like you might.
Blackbird, QUIT IT. It's too dangerous and old amps to use for guitars are cheap and everywhere. The strings will carry the hot current and could shock/kill when you touch them. Your unit is not something to learn on, Use it for radio parts and look for an old record player or console unit with a power transformer. I just bought one for $15. Look for a unit with a big power transformer and a smaller output transformer and avoid tube numbers that add up to wall voltage like 35L6/50L6. Look for 6V6/EL84 type power tubes and 12AX7 preamp tubes. Go to www.ampage.org for schematics, layouts and actual photos plus online help, Enzo is very good, he runs a repair shop in Mich. I think. Look at the tweed Fender Champ and Deluxe and be sure to remove the death cap shown on old schematics and replace it with a modern 3-prong plug. There are plenty of effects to add also.
Regarding the amplifier, no, you are not cutting out the 12SQ7. You are adding a preamplifier to the existing amplifier. When you're done, you'll have a 50L6, 12SQ7, and 12SK7 for your amplifier. The 12SA7 will serve simply as a filament ballast. The 35Z5 will be your rectifier. You may simply leave the 12SK7 wide open and keep the volume control on the 12SQ7, or you may also add another volume control to the 12SK7.
If you want to make your amplifier safe, put a 3 wire grounded cord on it. Put the switch on the hot side instead of the chassis side (wire it to the line wire that goes to the 35Z5). Connect the neutral and the ground wires of the line cord to the chassis or to B- if the set uses an isolated chassis. Wiring the amplifier in this way will assure that the chassis is always grounded if plugged into a grounded outlet.
I second that thought. I have seen the lead singer during one of my gigs fell on the floor after "kissing" the mike...I took readings of 120V between the mike shell and his guitar strings...Painful apparently. Never use a transformerless amp as a guitar or worse, an harp amp...
Not long ago, my Bro' also felt "funny tingles" after touching the other guitarist. One of the two was using a transformerless amp modified as a pratice amp...
Z-
MRO
Just don't use it dude. Look for a transformer unit to convert. I see them on the side of road sometimes.
Lewis L.
Hopefully he won't decide to wash it with the plug still in the wall.
Thomas, we understand what you mean. I'm not sure that blackbird has enough experience to be smart yet though. The no-transformer circuit mixed with the guitar string-ground circuit is just too deadly, he'll learn the same thing with a transformer circuit plus have known schematics for 6V6s to get the blues sound that he desires. It'll still be a junk project, heck most of the stuff around my house are junk projects, but I think they're beautiful. Blackbird here's what I look for and most are free, I even got a 12" Jensen in a 60's console once, a P12P actually. Have fun, Charlie.
http://cgi.ebay.com/VINTAGE-VM-VOICE-OF-MUSIC-RECORD-PLAYER_W0QQitemZ280078091969QQihZ018QQcategoryZ1442QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Now that we've reiterated the subject about 10 times, do you think he has a clue as to what we are talking about, or do we have to go over it another 10 times?
Seriously, people!
Lol
Yeah it's just for fun and learning actually, a practice amp that just I would use myself, no live gigs ect. I was actually going to ground it and add a fuse. I was just curious to hear the sound of an amp using something different than the usual 12ax7 pre.
Thanks for all the concern!
Thanks god I am not making an amp out of a microwave!
lol!!!!
Have fun. If you want, I can draw you a schematic, with variables and ideas, and even a negative feedback circuit. If you want, you can make the amplifier have push-pull for more punch and fine sound. It actually is possible to make a fine push-pull amplifier using a 35Z5, 35L6, 35L6, 12SQ7, and 12SK7. You will need a different output transformer, though. You will want a better speaker than the original radio speaker, too. An 8 inch speaker with nice full range will be fine (nothing fancy, unless you want crisp treble...then a coaxal cone is a must). If you're looking to just stick to the parts at hand, then you can keep it as single-ended. Adjustable negative feedback will allow you to play around with the tonal characteristics, as well as a bass and treble control.
Stay on the carpet, I've got it now.
