:Just took bach off a 30s set and see it is marked 25
:cycle.Will these work or can they be modified for 60?
:Thanks Greg -Back to the basement to see if I can get
:It going.With the temp in the single digits in northern Ind a great day to play wiyh radios.
When I was working on airliners, we routinely used 60 Hz test equipment (with power transformers) on 115 V. 400 Hz. aircraft power. Cold here outside of Atlalnta, too. Down in the 50s (F)
Saw Atlanta was misspelled as I hit the enter key.
Sorry, Lewis L.
The huge electric GG-1 locomotives running from NY to Washington since the 30's, ran on 25Hz at 11,000 volts, but they met their demise for the most part in the early 80's. They said the change to 60Hz was imminent and these old beasts would be obsolete. So they either destroyed or put the remaining few in museums.
http://www.steamlocomotive.com/GG1/
The big paradox here, is that though in a few areas, the substations were re-wired, the main NY-DC segment to this day is still wired at 25Hz. 11,000 volts, as it was built as in the early thirties.
Sorry to be off-topic, but sometimes it's a sad thing to see some of this historic stuff to be ended so pre-maturely.
:Yes it will work on 60hz, A 60hz set wounld not work on 25hz, power trans would over heat.
:Greg
::Just took bach off a 30s set and see it is marked 25
::cycle.Will these work or can they be modified for 60?
:Didn't New York City keep an offbeat AC frequency a bit longer than the rest of the country, such as this?
:The huge electric GG-1 locomotives running from NY to Washington since the 30's, ran on 25Hz at 11,000 volts, but they met their demise for the most part in the early 80's. They said the change to 60Hz was imminent and these old beasts would be obsolete. So they either destroyed or put the remaining few in museums.
:http://www.steamlocomotive.com/GG1/
:The big paradox here, is that though in a few areas, the substations were re-wired, the main NY-DC segment to this day is still wired at 25Hz. 11,000 volts, as it was built as in the early thirties.
:Sorry to be off-topic, but sometimes it's a sad thing to see some of this historic stuff to be ended so pre-maturely.
::Yes it will work on 60hz, A 60hz set wounld not work on 25hz, power trans would over heat.
::Greg
:::Just took bach off a 30s set and see it is marked 25
:::cycle.Will these work or can they be modified for 60?
