Are you replacing the filters and bad caps before firing these up? Excessive B+ draw will burn out the pilot lamp which causes the filament to go.
I wouldn't throw them all away - they are still perfectly good as a rectifier for a non-pilot lamp type radio! Just mark them as such.
35Z5s are notorious for the filament tap burning out. See Service Tip 40 from my site: http://www.philcorepairbench.com/tips/svctip40.htm
:Seems like every radio I own with a 35Z5 rectifier needed to have it replaced during the repair process. Took me a while to realize that the flash bulb effect on the pilot lamp is caused by one side of the center tapped filiment opening up. I have been through 5 this month. I know I should check the voltage divider network for the lamp, and the capacitor I typically find in that circuit. If I lose a 35Z5 tube, I usually just replace the cap with no question asked, and check the resistors, but I have never actually found either the cap or the resisors are bad. Is this just the nature of center tap rectifiers or is there something I might be doing that causes the problem?
S.U. Geston
